First Performance Mods Suggestions
Also, make sure your tires are good. Probably the best bang-for-the-buck mod is tires. Without them, nothing else really matters.
if you have any deffered maintenance i would get that done first, that would make your car perform at least to factory levels including safety.
Get rid of the stock mufflers at any cost, as well as the stock main cat and pre-cats. You can either go LT headers and true duals, or keep the factory manifolds and go to a 2.25" front Y into a high-flow cat then an aftermarket cat-back or factory with perf. mufflers. Get that exhaust moving efficiently!
Next is intake: The TPI "Wall" of 4500 RPM is a bummer. You can get around this in numerous ways, consisting of aftermarket intakes, porting, and/or siameseing the intake/runners. Or if you like the low-end grunt, you can go for a torque monster with a big lift, low duration cam.
Heads.. well, you may NOT need new heads if you're looking for less than 400hp, but some port matching would be nice if you want to get over 300.
A camshaft should be chosen by the powerband it generates, not by the amount of lift it offers. The target powerband for TPI is 1500-5000. Anything higher is useless with the stock intake. A perfect cam for a stock L98 would be 208/212 duration, .450-.460 lift, and 112+ LSA.
Hope this helps you out.
I'm a "no" vote on removing the MAF screen, just because the sensor is so fragile.
with exhaust + a 6psi supercharger with some gaseous intercooling
A LT-4 hotcam is a low-cost alternative. It's compatible with L98 motors. 218/228 duration with .485 lift using 1.5 rockers. Extra split would help with factory manifolds and/or lowish factory cylinder head intake-to-exhaust port flow percentage. A Hotcam would work well with ported/aftermarket heads later too. 1.6 rockers get this cam to .520 lift. Good results with with long or short-runner intakes. A hotcam setup is about the most reasonably priced cam upgrade.
I agree with making sure factory-installed systems are working properly first. Make sure of you base-line satisfaction -- and what it is.
Edit: Oh yeah, don't forget about gears. Depending on gears in your rear end, this could move up to #2 on the list above -- especially for the price.
but there is no arguing that modded cars will never allow the owner to recoup what they have spent, they'd be lucky to get 30 cents on the dollar for any mod.
so if you don't mind redoing the hardware, or just tinkering with it until you think you own that modification, go for it.
on the otherhand, most corvette owners who have maintained their cars have done some things to them....imho
and as far a labor forget about it, turns into a labor of love, all those hours, on your back in the cold or heat, busted knuckles, and trips to the hardwarestore, is all the pleasantries of motorsports...
whatever turns you on.
Check with Jon at http://fuelinjectionconnection.com
An inexpensive TCI shift kit in mine has provided many smiles, it cost about $30 and took an afternoon to install. These cars are so very slow stock. Consider new heads, cam, and intake. I pulled a full second off mine with few mods and little cost. Keep the best tires on as traction is very important.
