computer
Old Dec 18, 2008 | 05:06 PM
tuckers88's Avatar
tuckers88
1st Gear
Default computer
i have an 1988 ca vette and its have whati think is a computer problem , what it is doin is it will just died for no aparnt reason and i cant figer out why,it dose havea performance chip in her so i think that that is hurting it, can some oone help me????
Old Dec 19, 2008 | 12:25 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default vette
If you are having computer problems, they generally throw codes. Any codes?
Old Dec 19, 2008 | 08:17 AM
mseven's Avatar
mseven
I have heard of failures, but in my experience the stock ecm can handle quite a bit of abuse. You could inspect the prom to make sure is being held in by the 2 clips. I would also start looking for the problems elsewhere, such as dist. module etc.
Old Dec 19, 2008 | 10:36 AM
redrose's Avatar
redrose
FIRST check with ALL injected engines is FUEL PRESSURE... should hear the pump run for 2 seconds when the ign switch is first turned to "on" but not to "start" (may need to remove gas cap and put your ear near the hole while a helper turns the key if in a noisey area)... if you hear the pump hum, get a $15 tester from harbor fright...pressure should be near 40 psi,still hold 10 psi after 12 hour sit (don't need to run engine to do this test)
second check for spark...do NOT pull a wire off the top of the distrib (old school method) as the HEI may build enough "juice" trying to fire too much gap that it arcs internally and self-destructs, unplug a plug wire from any spark plug and use a well grounded spare spark plug to test...if no spark, the "ignition module" inside the distrib is a very common culprit (i carry a spare + tools in all my HEI cars)
Old Dec 19, 2008 | 10:41 AM
MikeC4's Avatar
MikeC4
The first thing you need to do is get spell checker!!
Old Dec 19, 2008 | 07:50 PM
rodj's Avatar
rodj
Define "died".
Won't crank ,
won't start ,
died while driving?
To computer
