A/C control unit on the fritz
Old Dec 18, 2008 | 06:18 PM
JB90vette's Avatar
JB90vette
Default A/C control unit on the fritz
Hello,
I have a 1990 vette and the (A/C - heater) control unit turns on and off by itself. I hear some clicking sounds in the dash....is this a relay problem or the control unit???
Thanks for your help,
Old Dec 18, 2008 | 11:11 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default 1990
Not sure about 90 but my 89 has the c68 electronic controls. You have the electronic or manual HVAC controls?
Old Dec 19, 2008 | 12:46 PM
JB90vette's Avatar
JB90vette
It's electronic.......push button's, no levers.
Thanks,
JB90
Old Dec 19, 2008 | 12:58 PM
runner140*'s Avatar
runner140*
Thanks,
JB90
Try the easy fix's first. Check out your check valve....universal check valves cost around $5.00. At any auto parts store.
Old Dec 19, 2008 | 07:45 PM
rodj's Avatar
rodj
Are you talking about the head unit inside the car or the heater blower ( fan )?
Old Dec 20, 2008 | 10:23 AM
JB90vette's Avatar
JB90vette
Not sure what you mean by the head unit, but the fan does turn a low setting with 75 deg. Sometimes I am able to turn the control off, however, it turns back on given a few minutes and gets stuck blowing hot air.
Driving in Florida with the heater on is a pain in the butt
Old Dec 20, 2008 | 10:25 AM
JB90vette's Avatar
JB90vette
Thanks a lot. I'll look into this and see if that helps.
JB90
Old Dec 20, 2008 | 06:24 PM
rodj's Avatar
rodj
Some notes.
Even if the valve on the hot water supply is stuck open , hot air is only obtained by the door inside the ducting directing air through the heater core.
A stepper motor moves the door as needed to get the set temp.Something is driving the door to hot.
Florida fix.
Put a manual valve in place of the suggested vac one on the coolant line to heater and turn on when needed.
To A/C control unit on the fritz
