Pulling to the right
Old Dec 19, 2008 | 11:05 AM
Am4wag's Avatar
Am4wag
Default Pulling to the right
I just changed the steering valve(?) assemmbly located under the driver's side that was leaking.This valve assembly has a ball joint on one end,and treads into a rod on the other.
Since,car wants to go right,and you have to hold the steering wheel in order to steer straight/keep from going to the right.Is it possible I screwed this assemly on/in too much on the rod....
Just had new tires installed and alignment checks out.
Old Dec 19, 2008 | 06:04 PM
Muffin's Avatar
Muffin
Suggest you post your question in the C3 Forum. More likely to get an answer.
