87 Vert star screw stripped on head
Being that it's holding the EGR pipe you need to get some penetrating oil of some sort in there. If it is tight enough in there to strip a Torx head, it's pretty darn tight. Second shock can really help with this sort of thing. Since I am guessing you are doing this at home and have a somewhat limited set of everything, you can try(with an extra) tapping the next size up torx bit into the head of it. You may even go up two sizes deoending on how stripped it is. This really only works as a last resort and if the head is deep enough.
Other than that you are looking at drilling it and going with an easy-out or such tool.
You may have to do some disassembly or creative thinking. Do some searching for tools on the alldatadiy.com site that I have provided around the site.
Can I ask why you are removing the tube?
If so you can weld a nut onto the head of the stripped bolt and back it out. A stick or mig will work for this. I know it is kind of tight in there but with some patience and luck you can do this. If using a mig, it needs to be a small portable with a small gun.
If it is the bottom EGR intake bolt, that is a VERY hard position to even get a bit on. If it's the top bolt, it'll be a little easier. First try the aforementioned technique of pounding the next size torx head in there. It worked for me, the larger bit grabbed the bolt so well it twisted the entire head right off!
If that doesn't do it, you're looking at drilling it out. I broke all 4 of the corner bolts on the intake and the rear two on each side caused any drill to be right up against the firewall. I ended up buying a 3/8" right angle air drill that did the job marvelously. If your normal drill doesn't work, and you have access to a compressor, this might be an option. It was the Harbor Freight one here.
If you can't access the bolt to drill it out because of drill length, go to your local industrial supply store, such as Grainger's (closest one is in Norcross, GA), and they will have good DeWalt drill bits in lengths of 18" or more. I know because I bought some from there.
If you go the drilling route, just heli-coil it and you'll never have to worry about cross-threading a bolt or reactions between 2 dissimilar metals because it is a stainless steel insert. Don't forget some tapping/drilling fluid either to keep the bit from getting too hot.
The welding idea is probably the best method, but requires a welder.
Good luck and keep us posted,
Jonathan
I replaced the ones at the header and the manifold with new deep-contact allen heads. If you want one of the old torxs, I'll send it to you for shipping, but I'd just buy a new one.
