94 randomly dies
Old Dec 21, 2008 | 03:55 PM
llesg's Avatar
llesg
Default 94 randomly dies
My 94 would randomly die while driving but would restart.
Now it won't start at all.????
Rick
Old Dec 21, 2008 | 03:59 PM
engle1147's Avatar
engle1147
Got any codes?
Old Dec 21, 2008 | 04:15 PM
WW7's Avatar
WW7
Could be either ( Ignition Control Module) or ( Opti ) --Both will act as you discribe.. My guess is ICM because of the restart.,WW
Old Dec 21, 2008 | 04:25 PM
llesg's Avatar
llesg
Originally Posted by WW7
Could be either ( Ignition Control Module) or ( Opti ) --Both will act as you discribe.. My guess is ICM because of the restart...WW
Cannot read codes. I tried with a code reader but it would not show any codes.
The opti-spark is a fairly new MSD.
How to check ICM??
Rick
Old Dec 21, 2008 | 07:09 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
94's are an odd-ball
They have an OBDII computer and connector, but run OBDI, so a regular reader won't work.
But the good news is you really don't need one.
You can make them come up on the dash
Here's how.
http://s242.photobucket.com/albums/f...m/ccm%20codes/
Old Dec 21, 2008 | 07:39 PM
MikeC4's Avatar
MikeC4
Here's another link showing you how to retrieve error codes. Remember, first determine if you have the old style OBD I connector(12 pins) or the OBD II connector(16 pins). After you have determined this, you will know which 2 pins you need to short together.
http://www.corvettebuyers.com/c4vettes/codes.htm
Old Dec 23, 2008 | 01:54 AM
llesg's Avatar
llesg
Thanks for the advise,I will check it out
Rick
Old Dec 23, 2008 | 09:10 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You can get your ICM tested at most auto parts stores (NAPA, AutoZone, Checker, O' Reilly, etc..)
Old Dec 23, 2008 | 02:13 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
95 has the OBDII connecter and ODBI computer. 94 is straight OBDI, to check the codes place a paper clip in the upper right hand pin hole and the other side in the bottom left. Then turn the key to the 'ON' position, section 1.0 are the CCM codes(code of 12 means the system is ok) and section 4.0 is the ECM codes(- - - means no codes) and a code followed by a C means current code and code of H means a historic code, i.e. 12C or 12H.
Old Dec 23, 2008 | 02:50 PM
simple green's Avatar
simple green
Just a thought but my 94 died and wouldn't restart once when the air inlet came off. Air was bypassing the MAF sensor and there were no codes. My system is modified though so that probably wouldn't happen on a stock setup.
Old Dec 23, 2008 | 11:08 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
RANDY93, sorry, but you are incorrect about the connector for a 1994. The 1994 connector IS a 16 pin, OBD2 connector, albeit with a computer running OBD1 software.
As mentioned earlier via link -- using the paper clip to gound pin 12 (CCM Diagnostics enable -- lower row, 4th pin -- counting from left) to pin 4 (ground -- upper row -- 4th pin, counting from the left).
All your other info is dead on and good info...
Old Dec 24, 2008 | 01:10 PM
llesg's Avatar
llesg
OK, so I have the 16 pin model. I shorted 4&12 and got some codes.
1. C 12
4. H 16
9.
A.
1.0
Can anyone tell me what they mean??
Also checked with some auto parts stores about testing the ICM but could not find anyone that would.
Old Dec 24, 2008 | 01:27 PM
M. Schumacher's Avatar
M. Schumacher
Everything is good except the H16. That's the dread "no low resolution pulse" from the distributor. The car will not run without it.
Old Dec 24, 2008 | 01:39 PM
llesg's Avatar
llesg
Here's the thing. I started it yesturday and ran with no problem.
The opti is an almost new MSD
So what is the "dread" no low resolution pulse ???
And more importantly ,how to fix???
Old Dec 24, 2008 | 01:46 PM
MikeC4's Avatar
MikeC4
just FYI.....There are 8 "low resolution" tracks on the Opti shutter wheel that tell the PCM the crank position. Each one of these tracks represent 1 of your cylenders(spelling?). The black thing at the top of this pic is an optical sensor that creates a linear pulse train that is fed back to the PCM to determine which cylender is next in line to fire. Notice that each one of the 8 tracks will produce a unique pulse width. There are also 720 pulses generated from the outer tracks for timing adjustements.
This is a pic of the shutter wheel inside your Opti :
This is what the resultant waveforms look like from the low and high resolution tracks :
Old Dec 24, 2008 | 02:37 PM
M. Schumacher
Adding to what Mike said, the low res track is how the computer knows which cylinder the rotor is pointing at. You could have an opti problem - there have been a number of reports of problems with new msd and other brand optis. There could also be a fault in the wiring, either preventing the distributor from getting the power it needs or from communicating back to the engine control computer.
The diagnostic procedure in the shop manual is three pages long. It doesn't help that your problem is intermittent. As we all know, those can be the hardest ones to track down. For a start, since the car is running, try jiggling the wires where they plug into the opti to see if there might be a bad connection there. When you encounter a no start, remove the 4 wire opti plug and check for voltage at the red wire (terminal c) to ground. (ignition key in run) No voltage, problem in power circuit. If you have it, then check between terminal c and terminal d. Terminal d is ground so if you lose it there it is a problem in the ground circuit.
This is the kind of job that really requires the shop manual to do it properly. You're kinda flying blind without it.
Old Dec 26, 2008 | 12:13 PM
ukpete's Avatar
ukpete
Any progress?
Old Dec 27, 2008 | 02:09 PM
llesg's Avatar
llesg
Originally Posted by ukpete
Any progress?
Not sure what to do at this point. Maybe just drive untill it won't start again.
How to get the opti checked??Does it have to be removed???
I think it's only the third or forth one I've put in!!
So to be sure, the H 16 code is the opti???
Old Dec 27, 2008 | 02:25 PM
RogerZ06's Avatar
RogerZ06
Yep h16 is low res pulse. Time for new optispark
To 94 randomly dies
