Bad Headlight Control Module?
Old Dec 22, 2008 | 03:19 AM
Vetster88's Avatar
Vetster88
Default Bad Headlight Control Module?
My R.H. decided to start winking.... If I roll it up it'll lower on it's own, If I hit the headlight switch as it lands it'll go back up. However, if it's not timed right the headlight will not roll up. tested with a test light and the only time power is shown is a blimp on when the headlights are turned off.
Any Ideas??
If it is the module where do I get one?? local dealer can't get it nor can any parts houses near by.
Old Dec 22, 2008 | 10:07 AM
Epimax's Avatar
Epimax
Sounds like the module to me. You can get a replacement module at ecklers, etc..
I bought one a while back but I can't remember where I got it. May have been mid america, or corvette central....or ecklers! Memory fails me!
Good Luck
http://ecklers.com/product.asp?pf_id=35495&dept_id=1477
Old Dec 22, 2008 | 11:44 AM
GKK's Avatar
GKK
I bought a replacement headlight control module from Mid America and it shorted out within a few days. Fortunately, the original still worked and it's been fine ever since.
The same headlight control module is also, used on the 87-89 Pontiac Firebird and the 87-88 Pontiac Fiero's.
To Bad Headlight Control Module?
