My SES light is coming on and I am getting a code 32 which is a faulty EGR circuit. It only happens when I have been on the interstate for about 15 minutes or so. The car seems to run fine. When I shut it down and restart the SES light goes off until I am back on the interstate again for 15 minutes or so. I have a service manual but the diagnostics require a scanner. Any ideas of how to find my issue?
9 times out of ten (assming no vacuum leak) it is the egr diagnostic switch located in the egr crossover tube. $10 fix.
Thanks Pete. After some reading here I'm thinking that may be my issue. I will test it first. I found this great post that explains the system and how to test the components. Much easier to understand than the FSM. http://forums.corvetteforum.com/c4-t...de-32-fix.html
Mine ended up being the EGR valve. The diaphragm on the valve rotted away, resulting in a vacuum leak. I replaced it with a new one, cleared the ECM codes and voila! No more Code 32.
i had the exact same symptoms you had. i replaced the egr temp switch
cheap part but a pain to replace (wire connector behind the distributor)
solved problem
Same here! Had the exact symptoms as avgjoe described and a new EGR valve fixed it.
And the proper way to figure out which of the above caused it is to put a vacuum on the EGR and see if it holds or not.I use a Mighty Vac. If it does then buy the switch.
Hey Joe have you been to my Bro-in-laws place in Harrisonburg Dave's Taverna?
Although mine was visibly deteriorated even before I completely removed it and applied vacuum via the Mighty Vac tool, so it was patently obvious mine had gone ****-up some time ago.
Dave's Taverna is a fantastic place to eat! I go there regularly!
I hope to work some more on the EGR issue this weekend and I will try all your suggestions. I've been out of town and very busy with work so I haven't had a chance to work on it. I will keep you posted on what I find. How hard is it to replace the EGR valve? It looks like it could be a big job at first glance.
Reason: wanted to ad something
