Trouble starting- help?
Car began having difficulty starting once it got cold. Turn the key and you'd hear a "click" as the starter engaged, but nothing. No "click-click-click" of a dead battery (and the battery is a near-new Red Top). Turn the key a few more times and eventually it'll engage and start right up.
Local dealer wants $505 for the starter, so I wanted to see if it could be anything else before I call up Fichtner...
Can't be the relay because I can hear the motor engage.
Definately not the battery because eventually it starts right up.
Thoughts?
Thoughts?
That said even if the terminals themselves are clean there can be corrosion inside of the coaxial casing that can cause this as well. Check the terminal on the alternator as well.
I would put good money that the battery is fine, just not getting a charge. Do you have a voltmeter?
The thought is that the electricity was arcing to the housing instead of going through the armature, thus causing the total lack of power. There was enough current to engage the solenoid to extend the gear, but current running through the armature was just shorting out.
We covered the exposed windings in funiture varnish (makes a very durable insulator) and re-assembled everything. It started right up, but the test will be how it works over the next few days.
If it works, it saved me the better part of $500. Can't argue with that!
