1985 ECM Repair???
Old Dec 30, 2008 | 10:32 AM
Muffin's Avatar
Muffin
First there is no baro read on the 85. Second, cherokee did you get the No Code 12 diagnostic sheets? If so what were the results? A simple question: When you turn the ignition key to run do you get a steady Service Engine Soon light in the DIC?
Old Dec 30, 2008 | 10:49 AM
BluRay's Avatar
BluRay
Oh man don't leave us hanging here. Then what input did it offer? If it's not speed density and it's not used for BARO, what the hell does it do?
Old Dec 30, 2008 | 07:59 PM
Muffin's Avatar
Muffin
BluRay not sure I understand you post. The 85 is not speed density. Power loads are derived from MAF input to the ECM.
Old Dec 30, 2008 | 09:44 PM
anesthes's Avatar
anesthes
He says there is a MAP sensor. He's not implying the '870 ECM is not a MAF based system, he's saying there is a MAP as well. I cannot verify, I know for certain on '870 fbody applications there is no baro or map sensor for any sort of calculation, but I have not had my hands on a corvette version of the '870.
I know some of the computer controlled carb's had a baro sensor for I think elevation but I wasn't aware of any MAF calibrations other than the LT1s using a map/baro sensor as well.
-- Joe
Old Dec 30, 2008 | 10:54 PM
cherokeecorvette's Avatar
cherokeecorvette
yes i get a steady light, I just got done troubleshooting the and it points to ECM being bad
Old Dec 30, 2008 | 10:55 PM
cherokeecorvette
I have voltage at ALDL and i ohmd the ground at ALDL
Old Dec 31, 2008 | 11:02 AM
Muffin's Avatar
Muffin
cherokee your ECM is available at most parts houses for $80-$90. That may be your best source. Yes they will be rebuilds but it may be the only game in town since the 870 was a one year application. Might try one of the salvage yards who are supporting vendors. Rebuilding yours may be a possibility, don't know.
MAF-MAP Application
82-84---L83---MAP
85-89---L98---MAF
90-91---L98---MAP
92-93---Lt1---MAP
94-96---Lt1---BOTH (MAF for flow/MAP back up) Includes Lt4
This table vadered from Corvette Fuel Injection by Charles D. Probst, page 70-71.
Old Jan 1, 2009 | 07:30 PM
cherokeecorvette
Thanks for the help every1 i orderd a reman. from the part store should be here tommorow ill let ya know wat happens after i put it in
Old Jan 1, 2009 | 08:42 PM
captmike13's Avatar
captmike13
Cruise-In IX Veteran
cherokee did you order a FSM yet?
Mike.
Old Jan 1, 2009 | 10:03 PM
cherokeecorvette
No im lookin for a good deal on one!! all the ones ive found were round $100 and with alll these problems ive been having cant afford one lol
