Code 43 on a 94LT1
Old Dec 26, 2008 | 04:41 PM
jim_hewett's Avatar
jim_hewett
Default Code 43 on a 94LT1
Replaced RH knock sensor.....no chg in driveability. Still bucking except under accelleration. CEL will come one and extinguishes. Taking a look @ the Opti Spark. Got an MSD in the box. Any suggestions????
Old Dec 26, 2008 | 04:47 PM
BluRay's Avatar
BluRay
You need to take a close look at the wiring and connectors at the sensor and at the opti, ICM, and coil. If it does this at idle it would make it easy for a wiggle test. just start shaking wires and looms until you can recreate the issue.
Be sure you run through this as well. Codes identify a trouble circuit, not a trouble component.
Keep us updated!
Old Dec 26, 2008 | 05:58 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Keep us updated!
Don't forget there are 2 KS to check. I am having this issue on cold mornings and goes away after a few minutes when it warms up.
Old Dec 26, 2008 | 06:20 PM
BluRay's Avatar
BluRay
Don't forget there is a specified torque on knock sensors. DO NOT put any kind of sealer or tape around them either. I can get you the torque spec. if you need it.
To Code 43 on a 94LT1
