Engine Compartment Lights
Old Dec 27, 2008 | 01:07 PM
flhtc01's Avatar
flhtc01
Default Engine Compartment Lights
Question...'89 coupe with L98. Since I just picked up my Vette, the engine compartment lights were not working. Upon investigating the issue it was determined that they were not hooked. Now, not hooked up would lead me to believe that they stayed on at some point in time and ran the battery down. I re-hooked them back up and lowered the hood slowly. The RH light went out about half way down and LH light stayed on. I completely shut the hood and re-opened it slowly while looking underneath. Both light were off initially and the LH light cam on almost immediately with the RH light illuminating approximately half up. I realize that these light most likely operate on a mercury switch. Does anyone know where these switches are and why one would light entirely different then the other one? If these switches are within the light housing themselves, would it be possible that one is in reversed from the other causing it to switch earlier? This just does not seem right to me. Any suggestions????
Old Dec 27, 2008 | 01:18 PM
aminnich's Avatar
aminnich
Switches are in the lights.
Old Dec 27, 2008 | 01:20 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
My hood is up all the time. Mine stay unplugged
Old Dec 27, 2008 | 01:22 PM
flhtc01's Avatar
flhtc01
In the lights? Meaning bulbs or in the light housings?
Old Dec 27, 2008 | 01:23 PM
flhtc01's Avatar
flhtc01
Coupe89,
Why is your hood up all of the time. It is not that broke is it?
Old Dec 27, 2008 | 01:29 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
They have a http://en.wikipedia.org/wiki/Mercury_switch in the light houseing. I installed a manual switch near the fuse holder infront of the left wheel well so if the hood is going to be up for a while I don't have to worry about draining the battery.
Old Dec 27, 2008 | 02:15 PM
aminnich's Avatar
aminnich
I did the same thing. Easy and convenient that way.
Old Dec 27, 2008 | 03:15 PM
86PACER's Avatar
86PACER
They are murcury bulbs. They turn off when the hood is almost closed.
Old Dec 27, 2008 | 04:47 PM
Ramrod92's Avatar
Ramrod92
No, the bulbs are standard # 211-2s Each underhood lamp assembly has it's own mercury switch built in, that's way they don't come on and go off exactly together.
Old Dec 27, 2008 | 10:01 PM
Race Prepared's Avatar
Race Prepared
Yep, I pulled the bulbs on mine - they don't provide much light anyway.
Old Dec 28, 2008 | 12:04 AM
yaknow's Avatar
yaknow
The mercury switch is approx. a 1/2" long cylindrical metal object located either right above or below the bulb behind the clear lense cap. It is attached by the same kind of clips that hold the light bulbs in place.
Old Dec 28, 2008 | 12:12 AM
BluRay's Avatar
BluRay
Well looks like I have something to do this weekend good idea!
Old Dec 28, 2008 | 06:05 AM
Weav's Vet's Avatar
Weav's Vet
I did almost the same thing. I just drilled a hole just under the light and spliced into the wiring on each light. Got toggles at NAPA and weather boots also. Works good and looks good.
To Engine Compartment Lights
