Surge at Idle
All plugs and wires have been changed recently.
Thanks,
Jrod
IAC tested and found to be operating correctly. Unplugged unit and checked resistance.
Checked for any vacuum leaks and none found.
Finally, cleaned MAF and throttle body.
The idle surges only when at operating temps (201 degrees and above).
Any other suggestions or what I should test next?
Sounds like your problem occurs only in "closed loop" ...
O2 sensor(s) perhaps.....
http://www.troublecodes.net/GM/
What is the rpm range of the surge? 700rpm normal to ???
In park, If you hold the throttle to increase to a steady 1K rpm, do you notice any surge ?
How many miles on your current Optispark ?
Once the car is at normal operating temperatures and the frequency of the surge is periodic like every few seconds. Range is 700 normal to 1000/1100 rpm.
58K miles on current (original) optispark
I haven't tried holding throttle in park yet
First Scan:
MAP Sensor 1.33v
Throttle sensor 0.60v
Battery 13.9v
Left O2 708 mV
Right O2 470 mV
Idle 625
Spark Advance 20 degree
Second Scan w/ idle bouncing a bit:
Everything nearly the same except O2 readings
Left O2 70mV
Right O2 88mV
Third Scan w/ idle bouncing a bit:
Left O2 572mV
Right O2 484mV
a general rule for fuel injected cars is that you want to see it switch about 8 times in 10 seconds. That would be .2-.8 (1) .8-.2 (2) .2-.8 (3). Yours may not see exactly but .1,.2, .3 or .7,.8, .9 is acceptable..
remember the car needs to be warmed to full temp(at least 170F) and should be held at about 1500-2000 rpm to check this.
* Connectors and wires
* Housing and insulator for cracks/damage
* Sensor tip for silicone contamination (white powdery coating)
Performance Test: Checks working range and response (speed).
1. Warm engine
2. Install DVOM between sensor and ground (2 volt D.C. range)
NOTE: Leave the electrical connection between the Engine Computer and the Oxygen sensor intact. Use of a test lead at the oxygen sensor connector is recommended.
3. "RUN" engine at steady cruise speed (about 2500 rpm)
o Voltage should vary at least eight times in ten seconds between 0.2 and 0.8 volts (normal range).
4. Drive system rich: The use of a properly adjusted propane flow-meter (J-26911) is industry standard.
o Voltage should increase to at least 0.8 volts within two to three seconds.
5. Drive system lean: Create a vacuum leak from a source that is not an PCM input or output.
o Voltage should drop to at least 0.3 volts within two to three seconds.
NOTE: After each test the O2 sensor should return to normal operating range within two to three seconds.
6. O2 Sensor should be replaced for failure to pass any of the tests above.
NOTE: A Computerized Engine Control system that is operating excessively rich or lean will drive the 02 sensor to its maximum range and should be repaired first and not diagnosed as a 02 sensor failure.
7. Reconnect all electrical connectors. Clear all codes set and retrain idle.
8. When two oxygen sensors are utilized, test one and repeat procedure for the other oxygen sensor.
DIAGNOSTIC AID:
If voltage is fixed at greater than 0.6 volts, a rich condition or contaminated sensor is indicated. Make sure system is operating in "Closed Loop" and check for Diagnostic Trouble Codes. Codes 45 &/or 65 should be present. Check for excessive fuel system pressure and perform injector ballance test.
If voltage is fixed below 0.3 volts, a lean condition, grounded or open oxygen sensor circuit, exhaust manifold leak, or AIR system malfunction is indicated. Make sure system is operating in "Closed Loop" and check for Diagnostic Trouble Codes. Codes 44, 63, 64, &/or 13 should be present.
NOTE: Remember, the oxygen sensor only senses oxygen in the exhaust. If there is an exhaust leak at the manifold, or a cylinder misfiring, whether the misfire is due to lack of fuel, lack of spark, or excessive fuel, there will be additional oxygen in the exhaust. This may cause the O2 sensor signal voltage to be low, and all the cylinders except the one(s) misfiring may be operating excessively rich while the system tries to compensate for a "false" lean condition.
1. Warm engine
DIAGNOSTIC AID:
Whenever I suspect a faulty O2 sensor, I just throw in a new one to see if the "symptoms" change, or swap the left and right forward sensors.
Otherwise, take a look at: a/c signal and make sure it matches compressor engagement; Coolant Temp Signal to make sure it's steady; Park/Neutral to make sure it indicates one or the other; and then your MAP which is used to signal the Load, though I'd just wriggle the harness around and see what happens with the idle. You could also aim a hair dryer at the ECM when its cold and if it starts to fluctuate, then the board may have a weak solder joint though most of these problems lead to a stall and not a surge. Finally monitor the TPS signal and battery voltage - both should be steady.
If your scan data reveals a rich condition, then take another look at things that might be letting in extra air causing the O2(s) to sense a lean condition including you header checkvalves or exhaust leaks.
Tested EGR on scanner and found the Duty cycle 99.4% under throttle and 0% @ idle. No vacuum leaks (hose in good shape) or no visable cracks in gasket.
Battery voltage registered 13.7v - 14.3v during cycle
When the surge in idle started - the IAC motor started bouncing all over the place. I unplugged the IAC and noticed the idle jumped up to 2K rpm and shut off the car and plugged back in and the idle went back to 700ish! I checked the resistance on the IAC and found it to be infinite.
I would expect the IAC to compensate for any other problems with idle - any ideas?
