Headlights
Old Dec 30, 2008 | 08:33 PM
buddylee432's Avatar
buddylee432
Default Headlights
Do the headlights or the motor run off of vacumm? I noticed when I put the hood on my 85 that it has hook ups for a vacumm hose. Is this suppose to be on to work. They dont work right now, as in the lights popping up out of the hood. The lights work just not the motor. Any ideas?
Old Dec 30, 2008 | 08:39 PM
janarvae's Avatar
janarvae
I believe all the C4 pop-up lights were electrical. If they are not working, but the motor is making noise, it maybe that your headlight bushings are toast. Check the sticky at the top of C4 tech to see if your symptoms match.
Old Dec 30, 2008 | 08:40 PM
StealthLT4's Avatar
StealthLT4
Nope, they are electric motors. I don't remember vacuum hookups, but a pic may help.
As for the lights not flipping up, what do they do when you turn them on? If they try to turn, or you can hear the motor running, it may be headlight bushings or gears. The bushings are a common problem, but they usually go pretty gradually, giving a fair amount of warning.
Old Dec 30, 2008 | 08:42 PM
buddylee432
No sounds at all. The lights come on but dont pop out. The motors have vacumm outlets... I dont know
Old Dec 30, 2008 | 08:45 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Those are drain tubes.
http://members.shaw.ca/dankai/Headlight%20Doors.pdf
Old Dec 30, 2008 | 10:44 PM
buddylee432
Traced it down to bad relays. Any ideas of a place with cheap headlight motor relays? Or are they cheap?
Old Dec 31, 2008 | 12:00 AM
buddylee432
Relays are 10 bucks each! Thanks guys
To Headlights
