Tire Balancing problems
Old Dec 31, 2008 | 06:21 PM
micks69's Avatar
micks69
Default Tire Balancing problems
I have a vibration that starts at about 62 mph (convenient speed) and have taken my ride for three balancing acts by so called professionals. Its driving me nuts. I normally do all my own work (two C3 frame off resto's) but this car only has 26k on it so I figured my wrenching days were through. NOT. I finally took the time to take a flash light and get under my car. Low and behold there is one weight on one tire, another looks like it flew off and no weights or evidence of weights on the other two rims. I made the mistake that I never make which is to leave the car while the crack team of 19 year olds worked on it. Never again. I am finding the nearest Hunter 9700 taking a can of brake cleaner and cleaning the inner rims myself before anyone under the age of 40 touches it. No wonder it vibrates, wonder if they even took the wheels off at the second two places?
Old Dec 31, 2008 | 06:43 PM
engle1147's Avatar
engle1147
Mick,
Get those wheels weights were they should be and make sure the tire balance guys learn how to CLEAN the rim......then apply the sticky taped weights.
If you still have a vibration issue ~ 60 mph or above check the 1/2 shaft U joints.
Old Dec 31, 2008 | 10:38 PM
HlhnEast's Avatar
HlhnEast
Also check and make sure the tire isnt out of round. It will vibrate no matter how well they are balanced.
Old Dec 31, 2008 | 11:26 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Originally Posted by engle1147
Mick,
on using the 'tape weights', have used them for years and years on 6 different sport cars, and only lost 2 over all that time.
However, I would use caution when using 'brake clean' on the rims, as the clear coat could be damaged, I'd only use soap/water/wax.
I'd instead suggest it's probably time for your annual super-cleaning of the rims anyway -- so remove each at home, remove all weights and give it a good cleaning inner and outer areas, put on a good coat of wax on all surfaces, then assuming you have another vehicle, load the 4 tires into your SUV/DD and take them to the shop for balancing with tape weights (or alternatively, put them back on with a torque wrench and drive the car to the service place).
Also ask the tech to use the 'family' setting. i.e. the accuracy of the balancers can usually be set at different tolerances (e.g. 1/8 ounce for 'family members' versus 1/4 ounce for 'customers').
Old Dec 31, 2008 | 11:31 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
I have had mine done on a Hunter 9700 and still have a similar issue new tires and shocks helped a lot but I still get some vibration above 60mph. Have had everthing checked by 2 different places as well as my own inspection and only slight issue is a little play in the steering rack. I hope a balancing solves your issue but after 3 times it has not helped me.
Old Jan 1, 2009 | 12:17 AM
No Go's Avatar
No Go
I've dealt with this a bunch...
I pulled the wheels and clean them as well as remove the old weights (techs usually scar the wheel when they remove the old stuff it seems). Then take it in for balancing...always insist on the tape weights and I then do the 'racer' thing of putting a layer of tape over the weight. Haven't lost a weight with this technique (without...three times!)
Lastly, I've balanced and rebalanced...even straighted a wheel to figure out the tire was bad...no fix on that. If they have sat long...might be a possibility.
Old Jan 1, 2009 | 07:04 AM
Weav's Vet's Avatar
Weav's Vet
Now that's a great tip! Thanks!
Old Jan 1, 2009 | 08:52 AM
the blur's Avatar
the blur
Even if you find a hunter balancer, 1/2 the guys don't know how to use them. I have wasted $100's if not $1000's over the years on balancing tires, only to still have a vibration issue.
Old Jan 1, 2009 | 09:14 AM
Tom Piper's Avatar
Tom Piper
Unfortunately, many don't know or care on how to do a "road force" balance.
However, if you find someone that does, it can make the difference between night and day.
Tom Piper
Old Jan 1, 2009 | 10:46 AM
jsinga's Avatar
jsinga
It's like almost anything, you have to find someone who can read. That's all it takes to run a Hunter GSP9700 balancer.
I took our Envoy in last week and they broke the wheel and tire to get a better road force match. It did make a difference.
JS
To Tire Balancing problems
