IAC valve buzzing....is this normal?
I'm trying to troubleshoot my car, it runs really rough and it has a slight miss. I have replaced everything...new heads, gaskets, ENGINE, distributor, rebuilt injectors, plug wires, plugs, cap, rotor, fuel pressure, checked for vacuum leaks etc.
I just noticed when I shut the car off, but left the ignition on I was hearing clicking / buzzing noise.....it ended up being the IAC valve.
Is it supposed to make a noise like that with the ignition on? It's brand new, but that doesn't mean a whole lot.
Thanks!!
DO a resistance check, and also, check to see if it was installed at correct pintle length, per instructions when you bought it.
Here is a forum post I did a while back
http://forums.corvetteforum.com/c4-t...ac-is-bad.html
Specs
Stock remanufactured 82 Corvette 350 Block and heads (less than 500 miles on both)
86 Corvette TPI converted to 1990 - 1992 Speed Density. 52 MM throttle body, heated o2 sensor.
Custom harness and all new sensors, including rebuilt and flow matched injectors
Stock HEI electronic distributor, plugs and wires (all new)
I also installed a CS144 alternator and upgraded the Big 3 so I know my electrical system is up to par.
I set the base timing at 6* BTDC with the est plug disconnected. I'm sure timing is right...I've done this many times so I'm a pro at it now.
My vacuum is showing 18-20....fluctuating between 18-20...not holding steady. It idles at approximately 750 rpm..but bounces to 500 rpm sometimes. Kinda bogs at idle, even when I'm not touching it.
My fuel pressure is holding a steady 39 lbs
I did a compression test and got
cyl 1 - 151
cyl 2 - 153
cyl 3 - 150
cyl 4 - 152
cyl 5 - 152
cyl 6 - 152
cyl 7 - 151
cyl 8 - 152
^ I think this is fine, to be expected for a brand new motor and heads.
I ran the car for about 15 minutes today to data log, when I turned it off...it would not start back up. I pulled the plugs and they had soot / smelled gas on them. I pulled them out to clean them. What could cause a rich condition like this?
I tried to propane trick to check for a vacuum leak, but didn't notice anything funny.
I have the stuff to data log and burn chips, I'm new at this so hopefully I can get this thing to run long enough to do a check.
One thing, about two months ago I went to a show in town..when I was leaving I got on the car a bit and it started acting funny. It died on me as soon as I punched the gas and I had to limp it home. I couldn't keep it idling or running, if I tried to accelerate it would die...I barely worked the gas to get it to move until I got to my driveway.
I need to double check my exhaust, it's "possible" that there could be a leak and screwing with my oxygen sensor, plus I welded the bung on myself and I'm not expert welder.
I hope I didn't leave anything out, if you guys have any ideas that would be great
