For the longest time...I have been fighting a rough idle/rich condition...and I think I just found why.
I have NO spark advance...ever. This would definitely cause a rich condition, popping out of the exhaust while cruising/decelerating, and a rough idle.
So...where should i look to figure this one out? esc module is new, est is plugged in. The only thing I've done to the system is the knock sensor bypass.
I bet this car is fun up top when I actually get proper spark back!
Knock system controls timing right? Maybe recheck bypass situation. Not sure here, but isnt timing controlled by ECM?
Good Luck. I understand your pain. Drives me batty when the vette isnt running correctly.
How did you bypass the knock sensor? Did you desensitize it or just unplug it?
We discussed this with you in the past.
The ECM needs to "see" the KC. If it doesn't, it probably assumes the KC is not working and defaults to a
low / no SA to prevent you blowing up engine.
How about hooking the KC back up and see if your SA comes back?
Can you elaborate on what you mean by "no spark advance"?
Does this mean 0 degrees at all times, 6 degrees or base timing at all times or 20 degrees advance relative to tdc at all times. Please clarify if you can.
I assume that when monitoring with a scan tool that you're seeing a fixed spark advance of 20 degrees relative to tdc.
knock sensor bypass was done by putting a toggle switch in the ground of the esc module. I removed and it made no difference. Only code is a 44....I need a heated o2. :o
tequilaboy:
On the scan tool, it shows spark advance: 0 at all times. base timing is set at 10 btdc.
One thing I'm unsure of though: could the scan tool cause a "fixed" spard advance, like when jumping the a&b ports and running?
does the icm control the spark advance? Or is it the prom?
does plugging in a scan tool to an '85 create fixed spark advance? car seemed to run the same with the scanner plugged in, so I'd assume not....need help here, kind of a serious issue.
Doesnt it make ajustments in timing as you drive depending on conditions?
It pulls timing out ( retards ) if it sees knock.Amount and time duration of retard can be changed on the chip
Originally Posted by CorvetteMike2004
.. a scanner is a read of whats happening.it doesnt change settings.
There is a setting (ALDL Spark Adder ) on the '165 ECM programming at least that adds in a fixed amount of advance when something is connected to the ALDL.
Why do you need a heated o2? Your car did not come with one.
Because when you install headers with the O2 in the collector, the stock sensor cools off below it's operating temp at idle and drops out of operation; puts the engine back into open loop at idle.
Now...knowing that...could the scanner be the reason I see that? I mean...should I be able to spin through first and second (auto) and pull right up to 7K rpms with no spark advance?
didn't think so...just going by what I saw on the scanner though. I guess on '85s, thats what you will see then...i need some verification on this though.
so if my Check engine light is on for a knock sensor, it is pulling timing automatically? i have a bad knock sensor that i plan to swap out... is this killing my power?
Check engine light ( code ) is a indication of a fault in a system ; no only of the item in that system.
The ECM checks the circuit.If it finds a fault it throws a code.
The fault could be the sensor, (in your case the KC) , or it could be a bad earth , loose connector, etc.
From memory if the KC circuit is in fault the ECM defaults to a low / no spark advance setting to prevent you blowing up your engine.
Hi Cord, my '85 is up on stands for the winter but I will be firing it sometime in the next few days to get it limbered up a bit. I can't remember if my cheap scanner will show timing but I will hook it up and see what it reads for you. I'll keep an eye here in case you get an answer. I'm a bit busy now or I would do it sooner.
Cord, I apologize, I kept you waiting for nothing. My Autoxray 2000 does not read timing. I even bought the extra program to allow scanning of OBD1 on it. This is what I get for trying to save $$$. At least this will get the thread back on top and maybe someone can give you an answer. Now I think I will go to THAT auction site and see if I can find a good unit.
