Heads
Old Jan 6, 2009 | 03:45 PM
shamdave's Avatar
shamdave
Default Heads
I have some valve smoke when i start her up. she has 91k on the motor so i was toying with getting the heads re done. The local machine shop quoted me 250.00 for the whole ball of wax.
I never did this before so do i just un bolt them and then re bolt them back on and tourqe to spec? or is this a job for a professional?
Input wanted ROCK ON
Old Jan 6, 2009 | 03:51 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Hmmmmm...
No, is not just like that
I know how to take the whole engine apart but when it came to heads, I sent them to Elliot Portworks and he did everything.
If you are planning on taking the heads off, let a pro do that kind of surgery. I highly recommend for you to buy the FSM (Field Service Manual) if you are thinking about doing that work.
Note: I started with a radiator replacement. Click below my signature
Old Jan 6, 2009 | 04:44 PM
reoch999's Avatar
reoch999
My local machine shop quoted $275 for a 3 angle valve job, mill, and assembly. So depending on what you're calling "the whole ball of wax" that sounds like it's at least in line.
Old Jan 6, 2009 | 04:52 PM
reoch999's Avatar
reoch999
of course that's if I bring in just the heads and new parts. it goes way up if they have to take the heads off and order parts.
Old Jan 7, 2009 | 08:46 AM
shamdave's Avatar
shamdave
I think I am going to jut go with a new crate engine. I only want to do this once jegs had a nice replacement block and heads for 1800
Old Jan 7, 2009 | 11:37 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I would bet all you need is new valve seals. These can be replaced with the heads on the car. If the compression is good, then doing this could save you a lot of money.
Old Jan 7, 2009 | 12:08 PM
JimiHendrix's Avatar
JimiHendrix
How many miles on the car? If she is less than 150k and running good, a valve job might be a waste of money.
Change the valve springs while you are at it. THey are less than 50.00.
Old Jan 16, 2009 | 02:59 AM
ZD1's Avatar
ZD1
Maybe its just me, but the cylinder head IS A BOLT OFF then ON. With the exception of the timing no thinking is required.
- head machining needs to include a 3 angle valve job, hot tank (or equivalen cleaning), surfacing, valve machining (standard angles or plus back cuts)
- gaskets: cometic head gasket, intake, valve covers,
- Torque wrench
To Heads
