Hedman Headers #68487 Help..
Old Jan 7, 2009 | 09:35 AM
WW7's Avatar
WW7
Default Hedman Headers #68487 Help..
On the (Hedman Headers #68487) it says that you have to modify the AC bracket to make them work, what exactly needs to be modified? Thanks .WW
Old Jan 7, 2009 | 11:43 AM
joe3906's Avatar
joe3906
No clue, but here's a bump for your cause.
Old Jan 7, 2009 | 02:13 PM
DarkBlue88's Avatar
DarkBlue88
From: Charlotte NC, behind someone going 10 under the speed limit
I don't remember modifying much on that side, maybe some spacers on the bracket and a longer bolt/stud but on the DS I had to make a new alternator support bracket. None of it was a big deal.
I couldn't get the PS header in without pulling the coolant switch out of the head(cause I didn't take any A/C stuff off), but i swapped a pipe plug in it with a quick hand and undid it after the header was in, and it didn't spill enough coolant to need repacked (lucky).
You can kinda see in this pic the spacers pushed the bracket out:
In this you can see the short ALT bracket, it was easier to make than mod the old one.
To Hedman Headers #68487 Help..
