95 Vette Overheating
Not trying to be rude, but most people getting into late model C4's for the first time are absolutely shocked by the normal operating temps these cars run at.
Normal:
Highway driving: 193 - 200
Sitting in stop and go traffic: 205 - 235
Your electric cooling fans won't come on until close to 228 F.
They will come on if the a/c system is running though. This is one car that will usually run cooling in stop and go traffic with the a/c on, than it will with it off.
Also, be sure and post the temp. that the digital display is listing.
So, I guess more details are needed on your symptoms before anyone can give further advice.
I've changed coolant with a complete flush three times in the 6 years I've had my '95. First and third times had no problems. The second time it took 5 or 6 hot/cold cycles before all the air got out and temps stabilized. And yes, used the bleed screw on the thermostat housing and the hot/cold cycle was from ambient to 260 and back to ambient (let it sit overnight). Took a week *&%^(%%.
Hope this helps.
PS Do not have the radiator pressure cap off at any time except when the system is fully cool and the engine is stopped. And use a 50/50 antifreeze mix, plain water will boil over. (Learnings from the second flush and coolant change.)
Also get under the front end or look from the passenger side between the A/C condenser and radiator. One plastic bag wreaks havoc.
Is the new thermostat the correct one for the LT1 (special design with extra plate on the bottom to cover the bypass chamber in the water pump) or has it failed (either mechanically -- the extra plate has a cap which fits over the main plunger -- ours actually came seperated after a boil over (left the cap loose) -- it can prevent the thermostat from openning all the way restricting water flow in and around.
Is the analog gauge's coolant temp substantially different than the digital dash temp? This could imply a flow restricting within the engine or spot boiling (insufficient pressure) or an air pocket preventing coolant flow through the engine. Frequently folks leave the cap off too long after starting the engine, preventing pressure build-up and movement of air pockets. Recommend cap off, start engine, confirm flow, top off, and then cap on -- all within 1-2 minutes at max.
Are both heater hoses hot and about the same temp? If not, perhaps there is a blockage which could cause flow restrictions and might contribute to the temps. Check the flow restrictor (looks like plastic connector in one of the heater hoses --- s/b near the wheel well.
Is there pressure build-up in the system -- i.e. when cap removed is there pressure? Has the cap been tested? Is there excessive increase in coolant in the overflow tank? If not, perhaps the cap is bad.
I'm betting on the air bubble...system must be burped.
