I just finished the LT4 swap and the fans run all the time .Before the ecm flash and after the flash. They didn't do this before the engine swap but right after initial start-up they run when ever the engine is running and don't shut off until you turn off the key??
1995 LT4 A4
I think that if you have the a/c or defrost selected no matter what temp you select, one of the fans will run. Also, if that is not the issue you may have a relay issue.
Usually the fan on the pass side only comes on if the car is running hot or you turn on the a/c.Both fans on all the time?
Did you make sure the relays are plugged in correctly,make sure they aren't cracked or broken inside.
If you unplug the ECM do the fans still work?
Still looking ,I know I have a 43 knock sensor .I am going to test for voltage on those tonite i have to do most of my work after 9pm I have 2 little kids to help tend to. i will look futher into it tonite.43 shouldn't cause the fans to fun though.??
