Catalytic Converter Recommendation
Old Jan 9, 2009 | 04:07 PM
Chris Kennedy's Avatar
Chris Kennedy
Default Catalytic Converter Recommendation
Hi!
Converter issues again: I am redoing the entire exhaust system on my '89 in preparation for a move to San Diego, and need to replace the main catalytic converter (the car uses pre-converters). Can anyone recommend a good main converter OTHER THAN the Magnaflow/Carsound converter (I have had quality issues with two such converters)? I am already aware of the Random Technologies converter.
Many thanks,
/s/ Chris Kennedy
Old Jan 9, 2009 | 04:33 PM
bczee's Avatar
bczee
There are the DynoMax or Dynatech one...you can find them in the SummitRacing catalog.
Not sure about the DynoMax ones.. but I have heard a few good things about the Dynatech ones, but it is listed as a Race only part.
I have not really talked to anyone that has used them.. most people I know have just used the Magaflow ones and then take them off and back on as needed to pass the smog test.
Old Jan 9, 2009 | 04:42 PM
Joe C's Avatar
Joe C
what kind of quality issues -
Old Jan 9, 2009 | 05:29 PM
Chris Kennedy
The problem:
The main inlet tube for EACH converter was not welded at a 90 degree angle to the main body of the converter---there was a slight offset to one side in each converter. The upshot is that this causes the back connector to the rear y-pipe to also be offset to one side, which throws the fitment off for everything there on back. Maybe there is enough free-play in the entire system to compensate (i.e., mounting the converter at a slight angle--although, this might require jiggering the front y-pipe, too), but, you, know, there are so many potential problems in fitting an exhaust system that I think it is stupid to start off with something you know is not right. Anyway, I have talked with the vendor and with Magnaflow (who said the angle should be 90 degrees but claimed they couldn't have someone in the warehouse check a bunch of these out and send me a good one), and have just decided to get another brand. The problem is that this is the brand that most of the Corvette suppliers sell. Maybe I should just spring for the Random Technologies.
Regards,
/s/ Chris
Old Jan 9, 2009 | 07:38 PM
GKK's Avatar
GKK
Any good muffler shop will be able to weld in any brand Catalytic Converter in the stock location, with no problem and also, warranty their work.
Old Jan 9, 2009 | 08:31 PM
856SPEED's Avatar
856SPEED
I have Random Technology on mine; my 85 only utilizes one cat, however....the Random Tech has been very good quality since it has been on the car since 2004.
Old Jan 9, 2009 | 08:47 PM
Vette Fast's Avatar
Vette Fast
Random Technology. My 86 has their true dual system in SS.
Old Jan 9, 2009 | 09:07 PM
l98tpi's Avatar
l98tpi
Max G’s
If you're redoing the entire system, try to get a 90-91 system, your converter will have collars that rotate on each end of the cat, allowing for easy alignment of system.
Old Jan 10, 2009 | 03:48 AM
Master__Shake_'s Avatar
Master__Shake_
I'd go with an OE style converter, to be safe, since those damn Cali tests are hard to pass. High-flow cats = fail miserably. The sniffer will bust you if it smells any worse than stock.
Old Jan 10, 2009 | 01:19 PM
Chris Kennedy
Thanks, everyone---I appreciate the advice!
/s/ Chris
Old Jan 10, 2009 | 03:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I had a RT main cat installed shortly after I got the '88 in 2000; with 100k miles on it, she still passes the OH dyno E-check...
Old Jan 11, 2009 | 01:59 PM
chozen1's Avatar
chozen1
high flow cats don't seem to last as long as oem cats(in terms of passing emmisions tests); i was told high flows have less of the precious metals etc than the oem cats;
not sure how strict california is, but couldn't you install the cat with flanges and have a test pipe made that you could swap once you pass the test? (not that anyone would ever do that right)
To Catalytic Converter Recommendation
