Throttle Body Coolant Bypass
Thanks !!!
1. No coolant spills everywhere if you need to remove the TB (for cleaning, painting, etc).
2. Plenum is cooler to the touch after running the car.
3. Cooler air enters the engine without hot coolant to heat it up. (supposedly)
4. Removes clutter from the engine bay with 2 less hoses.
Cons:
1. Takes 20 min to do.
Cons:
Even back in the day, GM was preparing for "The Day After Tomorrow" with this TB heating technique....
Even if the car isn't running, but the engine is, the heat transferred from block through intake etc. (the metals in contact with each other) will be enough.
I've road tested my car with TB coolant bypass thousands of miles in various different situations (temperatures near water freezing point - just above, just below - way below freezing point, in freezing rain, snowing, ... you name it) during this and last winter and there has been no problems whatsoever.
If the time 'lost' in this procedure is not considered, there are no cons.
Why do you think GM incorporated this system....just for fun ?
At idle (hi manifold vac) ,the pressure drop across the butterflies causes the air to cool allowing ice to form if the incoming air is cold enough and has enough moisture content.
Gas going from hi to low pressure cools.
As I stated above, I have tested this in practise, in all kinds of weather (in which water even could freeze and form ice) and I've had no problems. None. During last winter and this winter so far I have driven ca. 7 000 miles with TB coolant bypass.
On the F-15's I used to work on, we had heating elements along the leading edge of the wings and each sensor or probe. This was due to the high flow of air, cooler temps and humidity caused condensation on all leading surfaces and at altitude the water would freeze and weigh down the jet. Or even at our location the ice would build up on landing and take-off causing engine damaged from uice breaking off and being sucked down the intake.
If any one is familiar with Top-Fuel engine they know that Nitromethane is nearly a solid when it is ignited. Thus when there is improper ignition, the motors often grenades because of the fuel solidifying into ice.
This may be one reason... to keep throttle operational nominal or to keep ice from being injested.
Until we drive out cars in Death Valley, and then in Alaska (and test in on dozens of cars) all we can do is guess.
That being said, if your car is only driven in the summer, it would seem it is safe to bypass the throttle body.
Dale
This is what it looks like on a '91 L98. Toss the water pump frisbee while you have the air duct off (if anything, it makes putting the serpentine belt on SOOO much easier). How I did it:
1. Bought about 5 feet of 5/8" heater hose, two 5/8" caps (available in TB bypass kits sold at AutoZone) some hose clamps, and an e-z bend hose spring.
2. Drain coolant.
3. Remove hoses from TB, bottom heater core inlet, and TB to intake "U" hose.
U hose:
4. Place radiator hose grease on both ends of new hose with e-z bend spring over it.
5. Place end of heater hose over intake outlet. Bend hose spring to ~ 90*.
6. Route hose away from AC and tensioner pulleys. I used zip-ties and attached it to the AC line.
7. Insert into heater core LOWER inlet. You don't need to remove the high-fill reservoir - mine was off for cleaning and it was easier to access and snap a picture.
End result:
If you want more pics, just say the word,
-Jonathan
On TB;
Top hose on TB goes to rocker cover
Bottom hose on TB goes to charcoal canister by drv headlight
On mine, the top passenger side hose goes to the breather in the valve cover. The lower hose goes to the fuel vapor purge solenoid.
See the SILVER (just beneath the green one) hose clamp? That is for the hose that goes to the heater core.
