Opinion: When do shocks need replacement?
Old Jan 11, 2009 | 10:59 AM
nogoodsam's Avatar
nogoodsam
Default Opinion: When do shocks need replacement?
What is everyone's opinion on when to replace shocks?
Is it:
1) Bounce test
2) After XXX miles
3) After XXX years
4) Noisy
5) Because I have extra money to spend....
Old Jan 11, 2009 | 11:16 AM
87 vette 81 big girl's Avatar
I would replace shocks on a vehicle after the usual ride quality is gone over bumps in the road. Or over 50,000 miles. Replace them if oil is leaking from pistion - chrome rod seal.
Or You can allways just replace them Because You have extra money to spend !
Old Jan 11, 2009 | 11:34 AM
Weav's Vet's Avatar
Weav's Vet
I would say a lot of it would have to do with the quality of the shocks themselves. Obviously a more expensive shock would probably have a longer life span. I would say an average price shock would make it 40K.
Oil on the outside of the casing is always a sure sign one is done to. Usually if one has oil on it the others aren't far behind.
Old Jan 11, 2009 | 12:03 PM
StealthLT4's Avatar
StealthLT4
I would say I fudge (1) to justify my underlying reasons of (5)
Old Jan 12, 2009 | 08:49 AM
jmeyer58's Avatar
jmeyer58
Miles and time are poor judges of shocks, much like light bulbs, you don't need to replace them for those reasons. Leaking shocks, bounce test are the best reason but be careful, I have had bounce test show good when the shocks were starting to go. I just replace them if I have too much money, it helps reduce my wife's shopping time (read money).
Old Jan 12, 2009 | 01:16 PM
thethrillofspeed's Avatar
thethrillofspeed
The shocks that came on my 85 Vette were junk. I replaced them at 10,000 miles with cheap KYB's and the difference was amazing. Those beautiful aluminum A arms, fancy spring, and a shock that was about the same that came on a 1970 Nova...amazing.
Old Jan 23, 2009 | 02:47 PM
nogoodsam's Avatar
nogoodsam
Reminds me....I assume different year C4s had different standard shocks (in addition to options) ??
Old Jan 23, 2009 | 04:21 PM
thethrillofspeed
My 1990 ZR1 came with the adjustable suspension with bilstein shocks. It has 45K miles on it and they rock.
Old Jan 23, 2009 | 06:21 PM
ekess744's Avatar
ekess744
I say take them off the car and compress (at various rapid speeds) them yourself, that is if you know what a good one is supposed to feel like. the bounce test was very misleading for me. I thought all my shocks were bad, but what I really had was 2 good shocks and 2 bad, but I had already purchased all 4
Old Jan 23, 2009 | 06:46 PM
vader86's Avatar
vader86
Bilstein shocks will be well worn and should be replaced after 75K. Depending on how roads are in your area or how vigorously you drive it, it could be at 50K.
Old Jan 23, 2009 | 08:37 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
It depends on what your doing
Just driving around?
Taking it to the track?
Also what you've been doing
Track days?
drag racing?
Lousy roads?
Old Jan 23, 2009 | 08:50 PM
cv67's Avatar
cv67
St. Jude Donor '05
Bounce test. Some last a long time, some dont- many late model cars factory shocks (mostly junk) now are on their way downhill after 8-10k miles.
Old Jan 23, 2009 | 08:54 PM
C409's Avatar
C409
Its time when you have to wait a while before opening one of the beers you brought home
Old Jan 24, 2009 | 08:14 AM
tomtom72's Avatar
tomtom72
St. Jude 15 Year Donor
Active Streak: 90 Days
St. Jude Donor '08 thru '26
I generally use the porpoise test as a early head's up. We have some great roads in the NYC/metro area for this test. The heavy truck traffic at toll booth approachs causes the pavement to have regular waves that can be used to do the test. If that doesn't suit my needs, it's easy to find those same waves at spots on the most traveled truck routes. I just go over them at a good rate of speed & wait to see how fast the car stops porpoising.
Old Jan 24, 2009 | 09:08 AM
frenchyoliver's Avatar
frenchyoliver
you have forget this one:
s it:
1) Bounce test
2) After XXX miles
3) After XXX years
4) Noisy
6) when you see oil leaks.
Old Jan 24, 2009 | 07:26 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Replace them when they no longer control the body and/or wheels to your satisfaction when you are driving the car vigorously.
Larry
_________
"can't re-virgin"
Old Jan 24, 2009 | 09:56 PM
pologreen1's Avatar
pologreen1
IMO this order
1. leaking or oily
2. ride quality
3. major mileage
To Opinion: When do shocks need replacement?
