"ABS Active" light
Old Jan 12, 2009 | 10:46 PM
HeeHaw89's Avatar
HeeHaw89
Default "ABS Active" light
The ABS active light has been coming on in my '89 at strange times lately, and I can hear the pump running as well. It should only do it upon initial movement after startup. It will do it while stopped at a light then go off if I creep forward. Whats going on...thanks.
Old Jan 13, 2009 | 10:32 AM
jmeyer58's Avatar
jmeyer58
You may have a bad wheel speed sensor that gives a false reading when going very slow. Check the ac voltage output from each sensor at low speeds and see if there is one that is acting erratic (jack up vehicle and spin tire by hand about 1 revolutions per second). It could just be dirty or it may need replacing.
Old Jan 13, 2009 | 10:40 AM
engle1147's Avatar
engle1147
Remove each sensor and clean the crap off each of the sensor's pickup tips.
Old Feb 6, 2009 | 01:27 PM
HeeHaw89's Avatar
HeeHaw89
How do you remove the sensors?
Old Feb 6, 2009 | 01:59 PM
engle1147's Avatar
engle1147
There should be a sensor/pick-up on each of the 4 wheels. Remove the wheels from the car one at a time and you'll find a wire that goes directly to each hub area. At the end of the wire there is a sensor attached. Remove the retaining bolt that holds the sensor in place and pull the sensor straight out of the hub. Do not flex the wire too much as the insulation on it may be brittle from age and exposure. Clean the sensor tip (looks like a flat bladed screwdrive tip) remove any debris of shavings that may be stuck to it. Then reinstall it. If your handy with a voltmeter you can check the resistance to the sensor by finding the plug end of the sensor wire and check the resistances reading while slowly spinning the wheel. Depending on the tooth postion of the spindle in relation to the pick-up sensor's tip the resistance should be between ~900 and ~1,200 ohms...if you spin the wheels you should be able to see is cycle between the 2 ranges.
Old Feb 7, 2009 | 04:38 AM
HeeHaw89's Avatar
HeeHaw89
Good info, thanks. This is definitely on my to do list. Drove the car last night and the abs active light on along with the pump running constantly while stopped. Light and pump go off as soon as the car moves forward...very annoying
Old Feb 7, 2009 | 10:50 AM
engle1147's Avatar
engle1147
You may want to do a quick check to see the if the ABS single wire connector is still attached at the brake master cylinder.....this will cause ABS issues too if it is disconnected.
Old Feb 7, 2009 | 11:54 AM
Cashmo's Avatar
Cashmo
If a wheel bearing is going bad you may have metal shavings where the sensor is trying to pick up the signal on the rotor inside the bearing assembly. This would screw up the signal. Jack up the car and wiggle the wheels to test.
Jeff
Old Feb 7, 2009 | 12:41 PM
HeeHaw89's Avatar
HeeHaw89
Well I believe you solved the mystery. That wire was not "clicked" in very tight. Plugged it in tight and the symptom did not repeat. I was checking the vacuum line to the booster recently and must have inadvertently pulled it loose....hope this proves to be the cause, so far looking good
Old Feb 7, 2009 | 01:18 PM
engle1147's Avatar
engle1147
To "ABS Active" light
