L98 roller rockers
Old Jan 15, 2009 | 06:53 PM
covertte's Avatar
covertte
Default L98 roller rockers
thinking of installing on my 88
confused about self aligning or non self aligning
what do you recommend?
Old Jan 15, 2009 | 06:57 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
If it has the stock, non-hardend pushrods and guideplates you will need self aligning.
Old Jan 15, 2009 | 07:02 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Course he could by new pushrods/guideplates... Actually, I believe centerbolt valvecovers also require a narrow-body rocker. If you wanna get the good stuff, it looks like CC PROMAGs aren't cheap!
covertte's Avatar
covertte
it is a completely stock 88, so does that mean self aligning?
alsp is stock stud 3/8?
Thamks
Old Jan 15, 2009 | 08:30 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Yup, 3/8 stud.
Old Jan 15, 2009 | 11:53 PM
Kool88vette's Avatar
Kool88vette
I put a set of these in my 88. I guess you pick up about 15 HP. They are very quiet and I never had a problem with them. Plus they are easy to install.
http://store.summitracing.com/partde...6&autoview=sku
Old Jan 16, 2009 | 05:35 AM
covertte's Avatar
covertte
fhanks
Old Jan 16, 2009 | 04:11 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The stock self-aligning rocker ratio is 1.5:1; if you install 1.6:1 rockers you will need to remove the non-hardened OEM guide plates.
For this reason I installed hardened guides & push rods with 7/16" studs and non self aligning 1.6:1 CC ProMagnum RRs.
Of course you will also need new springs as the stocks are pretty weak even when new.
Old Jan 16, 2009 | 04:44 PM
Qiken's Avatar
Qiken
Why do you have to remove the non-hardened OEM guide plates when installing 1.6 rockers??
Old Jan 16, 2009 | 07:11 PM
covertte's Avatar
covertte
no disrespect
all i want is a simple install
all this business of guides etc is more than i want
i can live with 1.5 ratio, i am only looking to replace slightly wonparts
Old Jan 16, 2009 | 07:27 PM
AzCorvette84's Avatar
AzCorvette84
3rd Gear
Default L88 heads. Need Info
OK here is the stupid question of the day. I have an 84 Corvette that I am rebuilding (attempting) the engine on. I am about to place the heads on the block. They are identical so I did not mark right or left. Now when I go to put them on I find the water temp sending unit for the fan in the threaded hold on the rear of the head under the exhaust manafold. Now then, the other head has a hole in the exact location as the other head.
What goes in that hole?
I am ready to take all the obuse for being this dumb. I bagged and marked everything I took off and also took a picture of it, except for the heads.
Anyone that can help me I will be in debt to.
Ron
To L98 roller rockers
