Need Help
Old Jan 16, 2009 | 07:21 PM
MacKenzie452's Avatar
MacKenzie452
Default Need Help
The throttle cable broke on my 93. Got the part..just need to know how to do it. My dad said this was the best place to go. So....any suggestions?
Old Jan 17, 2009 | 06:24 AM
FlyingOstrich's Avatar
FlyingOstrich
No reply's ALLDATAdiy.com For a yearly cost has service manuals online.
Old Jan 17, 2009 | 06:39 AM
FlyingOstrich
Seems people need to be pulled over for this post
Old Jan 17, 2009 | 08:44 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I don't have my FSM at home and its not something I've had to do.
IIRC the cable goes from the pedal mount to the ASR and from the ASR to the TB.
I think they are seperate cables, I could be wrong.
From my old days fixing bikes (don't know if it works the same) we would pull the old cable from the sleeve and snake the new one through the sleeve. Don't know if that helps any.
I won't see my FSM until next weekend - car is apart in a friends garage.
Old Jan 17, 2009 | 08:49 AM
engle1147's Avatar
engle1147
Welcome to the forum....your dad is right this is the place to be. Your throttle cable change is pretty straight forward. The ends of the "new" cable will have stops already inplace. Fit the throttle cable through the hole in the firewall (where the "old" one was) then you'll want to just rotate each of these ends into gas pedal and throttle body linkage. You may have to remove the lower hush panel on the driver side to reach the gas pedal attachment point.
Old Jan 17, 2009 | 11:01 AM
MacKenzie452
Thanks for the info, hon. Appreicate it.
Old Jan 17, 2009 | 12:18 PM
joecarter85's Avatar
joecarter85
You'll need to open your ASR for R&R.
Old Jan 17, 2009 | 04:49 PM
elwood blooz's Avatar
elwood blooz
St. Jude Donor '07
I knew she would get the help she needed, thanks everyone!
To Need Help
