Lowering Steering Column
Old Jan 17, 2009 | 08:21 AM
JJS72's Avatar
JJS72
Cruising
Default Lowering Steering Column
I'm having difficulty lowering the sterring column in my 72 Corvette Coupe. I dismantled the trim, removed the two bolts and the column still won't drop so I can access and detach my left side speedometer and tach trim piece. Can anyone provide some advice...Juris
Old Jan 17, 2009 | 08:48 AM
TA's Avatar
TA
Try the C3 section
Old Jan 17, 2009 | 09:32 AM
joecarter85's Avatar
joecarter85
It's been a long time since I had a C3, but I remember having to drop the steering column. I think there is also a support bracket at the firewall as well as the 2 bolts you already removed.....
To Lowering Steering Column
