Engine swap
Old Jan 20, 2009 | 05:14 PM
Nathan Plemons's Avatar
Nathan Plemons
Originally Posted by BrianCunningham
If you did a leakdown test, then it's the rings.
You can get shortblocks as well as longblocks from GM.
For what they're getting for a shortblock, you can get one of these non-rollercammed longblocks
http://store.summitracing.com/partde...3&autoview=sku
http://store.summitracing.com/partde...9&autoview=sku
Keep your original engine for rebuild later.
I would recommend getting a roller cam version though if at all possible. Why take a step backward in technology?
Old Jan 20, 2009 | 05:16 PM
Corvette Chris's Avatar
Corvette Chris
I wish my 86 was a roller cam.
Old Jan 20, 2009 | 05:18 PM
anesthes's Avatar
anesthes
A hydraulic roller will have the edge under 6,000 RPM and will produce a hair more power.
A flat tappet won't explode at 7500 RPM like a hydraulic roller will from float.
A solid roller will work to 8500 with no problems.
-- Joe
Old Jan 20, 2009 | 05:23 PM
Nathan Plemons
-- Joe
With the right lifters and springs, you can turn 7500 with a hydraulic roller. However, that wasn't my reason. A hydraulic roller can have a more aggressive lobe for any give duration and thus make more power. It's also less friction and they virtually eliminate wear. Besides, since he's talking about using it with a TPI, 6000 RPM is really a moot point, let alone 7500 or 8500 !
Old Jan 20, 2009 | 07:11 PM
Iroc57's Avatar
Iroc57
Wouldn't this be considered an unnecessary increase in budget. If the $$$ are the same or close it makes sense but for street thumping if it is more than a $200 difference I can't see the benefit.
Just my $.02
Old Jan 21, 2009 | 03:18 PM
mavidatt's Avatar
mavidatt
would i be able to put my tpi intake from my original motor on the gm engine from summit, if so, i would probably go through with that.
