Engine swap
Old Jan 17, 2009 | 02:37 PM
mavidatt's Avatar
mavidatt
Default Engine swap
How hard would it be to switch out my tune port injection engine for a carburetor engine? I know the intake is different on the two, but would a carb work in an 89 vette? What would I have to change to make it work, if I was getting a completely new engine. I was looking at the GM Goodwrench engine on jegs, in particular.
Old Jan 17, 2009 | 10:36 PM
Iroc57's Avatar
Iroc57
Low profile intake, carb, distributor, return style regulator, and a lock up switch for the converter if auto.
I think that you asked this question already and I recommended just buying the correct engine.
Is there a reason that you want a carb?
Old Jan 18, 2009 | 08:59 PM
mavidatt's Avatar
mavidatt
yeah, the reason i want a carb is because i need an engine on a lower budget, the gm goodwrench engine on jegs is a good price for me. Everywhere I have found a tune port engine it is out of my price range. If you know a place where i can find a tune port engine setup, for an 89 corvette that would help out a lot. I can get a tune port camaro engine for my car, but then i would lose 20 horsepower, which i dont want.
Old Jan 18, 2009 | 10:05 PM
QuikZilver's Avatar
QuikZilver
Why not just put the TPI on the new motor? You just need a fuel pump block off plate. Everything else shouldn't be a problem to switch to the new motor. The motor doesn't need to be a TPI motor...they are all Gen I motors. My guess is the TPI motor includes the intake, which is why the price is higher.
Old Jan 18, 2009 | 11:43 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Plenty of people on the forum have done it.
The only trouble would be if you pick an engine with vortec heads, then all you'd need to do is put a different base on it.
Old Jan 18, 2009 | 11:46 PM
mavidatt's Avatar
mavidatt
so just buy the short block. . .
Old Jan 18, 2009 | 11:49 PM
mavidatt's Avatar
mavidatt
is theyre any recommendations for where i can get a short block that'll work with my 89 tpi with aluminum heads
Old Jan 19, 2009 | 12:01 AM
BrianCunningham
What's wrong with the car?
That will tell you whether you need a short or a long block.
Old Jan 19, 2009 | 12:04 AM
mavidatt's Avatar
mavidatt
compression problem
Old Jan 19, 2009 | 07:40 AM
Iroc57's Avatar
Iroc57
You are looking at $500 for the carb set up by the time you are done so add that to the price of the engine.
Have you called jegs yet and asked if you could bolt the TPI on that engine?
Old Jan 19, 2009 | 08:18 AM
BrianCunningham
compression problem
If you did a leakdown test, then it's the rings.
You can get shortblocks as well as longblocks from GM.
For what they're getting for a shortblock, you can get one of these non-rollercammed longblocks
http://store.summitracing.com/partde...3&autoview=sku
http://store.summitracing.com/partde...9&autoview=sku
Keep your original engine for rebuild later.
Old Jan 19, 2009 | 03:30 PM
dogbon's Avatar
dogbon
Default engine swap
Just go with a longblock. I did the carb conversion and it isn't worth the hassle. It makes a little more horsepower, but not enough to justify the work.
Old Jan 19, 2009 | 04:27 PM
mavidatt's Avatar
mavidatt
Ive called them multiple times and got different answers from different people. One guy told me though that it would not work with tpi intake, but he could sale me the short block and it would work.
Old Jan 19, 2009 | 04:30 PM
Corvette Chris's Avatar
Corvette Chris
Throw the TPI on it and be done with it.
http://paceperformance.com/index.asp...&ProdID=194848
FWIW, I think this deal is pretty hard to beat. I've come close a few times.
Old Jan 19, 2009 | 04:48 PM
Iroc57's Avatar
Iroc57
Of course the short block would work, you are using your heads. I honestly don't know enough about the difference for the heads on a TPI so I can't advise you. I hope that I am not breaking any rules but I bought my big block from this guy:
http://cgi.ebay.com/ebaymotors/SB-CH...Q5fAccessories
I even had a small warranty issue (bad lifters) that he resolved quickly. He can at least point you in the right direction. I am just one customer so don't take only my word on this.
Old Jan 19, 2009 | 09:21 PM
mavidatt's Avatar
mavidatt
Would this engine work with a tune port injection intake, or does it have to be carb?
Old Jan 19, 2009 | 09:23 PM
Corvette Chris
The heads are supposed to be the same as the 10088113 castings -- the ones on your 89 currently. So really, its plug and play -- minus a tune for the bigger camshaft.
To Engine swap
Old Jan 20, 2009 | 11:41 AM
mavidatt's Avatar
mavidatt
the zz4 base from pace performance is looking like a pretty good option. Will have to wait and save up a lil more for it though, unfortunately. So I could just throw my tpi intake on the zz4 base and it should work.
Old Jan 20, 2009 | 03:04 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
The cheepest way to go is find a exact replacement for what you have. When ever you change from what it was born with you asking for many hidden cost.
Old Jan 20, 2009 | 04:30 PM
anesthes's Avatar
anesthes
With the rate of C4's getting parted out on here, you would think he could find a complete L98 for around $500.
-- Joe
