90 Stuck In Low
Old Jan 18, 2009 | 11:38 AM
diguy39's Avatar
diguy39
Default 90 Stuck In Low
My 90 350/AT is stuck in low. Does this mean a trans R&R for sure? Any other possible situations I should or could check regarding systems? Thanks for any help.
Old Jan 18, 2009 | 11:44 AM
Pete K's Avatar
Pete K
Your governor is likely the problem. Grab a shop manual, and pull off the rusty cover on the drivers side. If the gear is shot, they are available for a few bucks. If the gear is goo, clean the valve well, and be sure it moves smoothly.
Old Jan 18, 2009 | 11:55 AM
engle1147's Avatar
engle1147
Check the fluid level. Have you done any work to the car that may have caused this issue? Will the car ever shift?
When it is cold (below 45 F or so) and I first start my car in the morning the car doesn't want to shift out of first until the fluid warms up a bit takes about 5 min. or so...then the tranny acts normal the rest of the day. From what CF members indicate I have debris in the valve system (FSM) or a bad govenor gear. I haven't dug deeper into my no shift issue since I live in FL and the temps never cause the problem for more than just a few days a year.
Old Jan 18, 2009 | 10:51 PM
diguy39's Avatar
diguy39
Thanks for the helpful info, PeteK. Since I posted this thread I had a chance to look through past posts and found a bunch of good info. Is the governor from Sannex a good way to go? I don't want to screw with anything other than factory specs/settings. The problem first occurred soon after my girlfriend Dian and I bought the 90. Regular driving, no problem, mash the gas for a thrill on the freeway and get off the freeway, street driving had hard shifts, starting up cold would see the trans bang into low from park and wind out before shifting. I don't want to bore you with this crap, enough's enough. I hope the governor change out does the trick. Can you recommend a place to get a good or better shop manual? Thanks again.
Old Jan 18, 2009 | 11:17 PM
Klondike's Avatar
Klondike
Don't know if the newer transmissions have one or not, but a friend's C3 did the same thing and it was the vacuum modulator. It was just a few bucks at A-zone and was about the size of golf ball. It screwed into the rear side of the trans from under the car and had a little vacuum line on it. Car would go into reverse and drive OK but just stayed in low gear and would just kind of coast when you let off the gas. The vacuum modulator fixed it. Hope yours is that simple.
To 90 Stuck In Low
