code 21 high idle
Old Jan 19, 2009 | 08:51 AM
sweets's Avatar
sweets
Default code 21 high idle
89 vett set a code 21 tps. tps tested good. changed out ecu no difference.could not get it to set a code 22 in testing.reset the iac to correct the idle and when it sets the code again i start it back up and the idle is back up to 1500 to 2000 rpms. HELP
Old Jan 19, 2009 | 08:53 AM
86PACER's Avatar
86PACER
What voltage do you have the TPS set at idle?
Old Jan 19, 2009 | 08:58 AM
sweets's Avatar
sweets
0.7 and it rools up smooth to about 4.3
Old Jan 19, 2009 | 09:06 AM
86PACER's Avatar
86PACER
That's you problem right there. 0.7 volts is too high. Code 21 means the voltage signal from the TPS is too high. This causes your high idle.
Factory spec is .54 volts with throttle closed (idle or key on). Backprobe the two upper TPS wires with a voltmeter while leaving the TPS connected. Engine does not have to be running, just the key needs to be on. Loosen both torx screws and move the TPS by hand till you get .54 volts with throttle closed, and about 4.0 volts wide open. Restart car and report back.
Old Jan 19, 2009 | 09:09 AM
sweets's Avatar
sweets
its down as far as it will go. could my tps be bad?
Old Jan 19, 2009 | 09:13 AM
86PACER's Avatar
86PACER
Yes, factory spec setting is .54. Idle starts to rise real high once you start going about .70 volts and higher. Is this your old TPS or a new unit? I've gotten bad ones right out of the box that don't allow for a proper setting like you are describing.
Old Jan 19, 2009 | 09:28 AM
sweets's Avatar
sweets
yes this is my old one. i bought one from a auto parts house and it didnt run any different but thats been three weeks ago, i might not have set it right. it was also a cheap part not gm.
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Have you tried rocking the switch, forwards or backwards, top and bottom. ??
Old Jan 19, 2009 | 09:32 AM
sweets's Avatar
sweets
yes while watching the voltage. what should the voltage and ohm readings be on each of the lines in? a b and c.
Old Jan 19, 2009 | 10:06 AM
WW7's Avatar
WW7
Make sure the tps is set into the TB lever correctly, many people get it into the seat wrong and it won't adjust right..WW
Old Jan 19, 2009 | 10:19 AM
AGENT 86's Avatar
AGENT 86
A is ground
C is 5 volts from ECM
B is output of potentiometer= .54V> close to 5V, to ECM
To code 21 high idle
