C4 of Year Winner (appearance mods) 2019
Selecting a timing chain...
How do I tell if a timing chain (esp dbl roller) will fit under the stock cover? (before purchasing it)?
On Cloyes website, there are several options for a 1989 (9-1145, 9-3145, etc...) The main variable is the number of slots/positions + the center distance.
How do I pick my option? (I'm probably going to need a 4-degree option). The two numbers listed above include that but I can't tell any other difference. Plus many/most chains on Summit's website list inability to fit under stock cover. Since that includes multiple engine sizes, I wonder if it's a problem for smaller motors only?
Any other recommendations for bang/buck?
BTW: Is there any well to determine which smallcaps would replace my standard HEI? TPI_Parts sells one... but's it's $120 more. (I understand either option would require coil & harness).
I bought the Cloyes double roller from Napa.Used the stock marks on it.Lost the instructions,called Cloyes and their tech was very helpful on which marks to use.No problem with fit under stock timing cover.Don't foget to lube it up good before you button her up.
The 9-3145 has three keyways -4*, straight up, and +4* degrees. That's the one I'm running in my LT1. It is a very well built, heavy duty timing set. Also, it is listed for the newer roller block engines.
I'm running a Romac billet Rollmaster. 9 keyways of adjustment. Fits under L98 cover just fine. Do a search for Romac Rollmaster online. They are very nice units and I believe they are reasonably priced, but I got mine 2nd hand like new never used so i didnt pay full price
BTW: Is there any well to determine if this smallcap would replace my standard HEI? TPI_Parts sells one... but's it's $120 more. (I understand either option would require coil & harness).
Judging by the detail in your posts and the time you are taking on your build you will not be happy with this distributor. I used a "knock-off" for the same price on mine and it works but I don't care about precise timing at every RPM. I just time it an go.
I'd go with a Cloyes Roller, they have many more options than that but its affordable and reliable. I got one for my '85 for $30 and its much stronger than the stock one.
I'd go Cloyes too. I used the Hex-A-Just in my 408 and just replaced the chain in my other hi-mile 85 with a Cloyes 9-1100 Street True Roller for only around 30 dollars. When I look at the two chains themselves side by side they look about the same. The Street True Roller has multiple crank keyways too for a 4 degree advance if you want it. That 9-1100 fit just fine under my stock cover but that was on an 85 engine. Since yours is an 89 with a small nose cam (factory roller) you will probably need a 9-3145 or 9-1145 though.
