Well, after living with my rough running 434 for a couple of years, I decided to pull it myself and have somebody go through it and see why it never ran right. I found a shop near me that has a good rep and will hopefully be able to give me a diagnoses and suggestions for improvement. Hopefully the parts are ok and this will be more or less a "freshening". However, I think I am going to replace the miniram with something else. This shop has a superflo engine dyno with the capability to run it with Accel DFI which is what I run my car on. Once we are all satisfied that it is broken in correctly and everything is running right, I'll put it back it and bring it back to them for a final tune on their Superflo chassis dyno. Stay tuned and I'll take some video of the engine running on the stand. My best #'s were 480+ rwhp with the current combo and tune. I am hoping for more streetability with similar numbers.
Must be something in the water, I am pulling mine this weekend, I think I might have bent or twisted my crank, sounds far fetched but above 3k rpms, it vibrates, very predictable, always the same.
Hope neither of these turns out to major. When your as far in as you guys, you want it right!!! I remember one HP motor I built in the 70's spun a rod bearing after 30 miles. After that went 65,000 miles no problems. Will be waiting to hear what you find.
Let us know what you find !
Sorry to hear about your set up Larry. This whole thing started out with a clutch change. That RAM set up didn't last long . Motor's out, tranny's out, and I'm going to take the rear out to have it re-sealed. Maybe I should gut the interior too Are you sure your vibration is that clutch system? Whoops, forgot you went with the Tremec
Reason: wrong info
Boy I hope everything is okay. I kept to a formula fairly close to you guys. Please post with latest findings.
Wood NM
<a href="http://s494.photobucket.com/albums/rr307/gamewood/afghan/corvette/?action=view¤t=SANY0212.jpg" target="_blank"><img src="http://i494.photobucket.com/albums/rr307/gamewood/afghan/corvette/SANY0212.jpg" border="0" alt="yes it is a 427!"></a>
...My best #'s were 480+ rwhp with the current combo and tune. I am hoping for more streetability with similar numbers.
I surely would have guessed that your combo would deliver better numbers than 480WHP. You have me beat in cubes and (I feel certain) SCR, yet I am still in the same area regarding power NA. Something must be amiss.
So the new Ram/ZF push option clutch did not last?
I have checked everything possible looking for the vibe, last spring I took the FW and PP off and had it rechecked and the balance was dead on. I rebuilt the heads and the swapped out the balancer and sent the Fuel Injectors to Rich at Cruzin Performance to be checked, and replaced a faulty HEI module and checked the distributor runout and swapped the plug wires and the plugs
so unless it is the oil pump bent or something like that , it only leaves a bent rod which I doubt or the crank,,, once I get it on the engine stand I hope to know more.
Yes, I would have to agree. They are going to dismantle the motor and lay every part on a table and we are going to go over it piece by oily piece. I'll bring my camera
Well, I have an initial diagnosis:
All 8 exhaust valve guides are gone. The valves were basically floating in mid air. I have 2 spun main bearings and the head gasket on two cylinders were just about blown out.
The good news is that the pistons are ok as are the cylinder walls. I'll have the pistons coated to bring back the clearance. I'll hopefully be able to take pics tomorrow. Got the flu today
Sounds ugly, but not too bad in the scheme of things I guess.
I am curious as to why you have cylinder bore wear on such a fresh combo? Unless your bores were honed to the loose side of spec. My builder likes to stay on the looser side of the piston to wall spec for a safety margin in an overheat situation.
Wow, I would have thought you would have some big time valve cover pressure/blow by
Well I'm glad you found some obvious stuff Dave. I think I know exactly what you just went through. I couldn't believe my eyes when I walked into the engine room of the shop that dismantled mine.
My valve seals were riding at the top of the stems, no woder our cars smelled exactly the same!!
Are you interested in a lightweight crank or Aluminum block?
Was the geometry off? Sure they will measure pushrods and figure out what went wrong. Sorry to hear about your woes, just make it bigger, badder and meaner.
He said the geometry was really good. The guides were worn in a complete circle which he said he has never seen before. If the geometry was bad, the wear would have been oblong and would have probably sheared the top of the valve thereby dropping it into the cylinder. Guess I got lucky.
The motor is about 4 years old and he said the crank was "old school" crossed drilled. They don't normally install those anymore. Anybody have insight on that??
