LT4 Rough Idle
Old Mar 15, 2009 | 01:19 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
So did you do the opti work before this? What exactly did you do? If you just changed the cap and rotor ,after the codes you had and dripping WP,odds are your opti will not be reliable with just a cap and rotor.
Old Mar 15, 2009 | 10:28 AM
vstol's Avatar
vstol
Just ran a codes check again and got a MAF 48 code, remember I am running a PCM for Less OBD 1 programed ECM. Will change the MAF and see what happens. Advance Auto has one from CARDONE for $125, new sensor, remanufactured body 1 yr warrenty. Their WEB site it exceeds the original anyone use it?
Old Mar 16, 2009 | 03:09 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I helped a buddy install a Cardone Opti from AutoZone on his 1995 'Vette. It lasted about two weeks before it went ****-up.
Ghetto garbage, IMO. On par with Python fuel injectors. You get what you pay for....
Old Mar 16, 2009 | 03:53 PM
DVNCI's Avatar
DVNCI
I think I paid around $75 here on CF for an OEM low-mile sensor, I'll do that any day of the week over a non-GM MAF - these MAF's are very, very sensitive, most important sensor on the car probably.
Old Mar 16, 2009 | 08:35 PM
vstol's Avatar
vstol
Thanks I have found a GM sensor for $190
Old Mar 29, 2009 | 06:48 PM
vstol's Avatar
vstol
New MAF sealed the deal, runs great
