Thoughts about LT1 IAT relocation (with numbers)
Old Jan 21, 2009 | 09:25 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Thoughts about LT1 IAT relocation (with numbers)
Most people will tell you that this modification is junk, myself being one of them. Still there are a very few people who say that it's a good mod and gives a more accurate picture of the "real" air temperature. Note I am referring here to the LT1 where the IAT is located in the rubber duct, NOT in the metal intake. The L98 MAY be different but I would have to data log one to find out.
The claim is that by relocating the IAT closer to the air filter, you get a more accurate reading because the sensor is not affected by heat soak.
I say that you want the sensor as close to the air going into the cylinder as possible because that will give you the most accurate information. People claim that the sensor heat soaks and gives a false warm reading, I say the air is moving so fast, that it keeps the sensor cool and doesn't have time to heat soak anyway.
To prove my point, I was just looking at some data logs. The first data log is from a 12 minute drive to work.
The data log starts with engine temperature at 66.7*F and IAT temp at 68.9*F. Due to manufacturing tolerances and physical location differences, I think you could call that "the same." The car had been parked in my cool garage overnight. 12 minutes later when I parked the car, the coolant temperature was at 188.2*F and the IAT was at 70.5*F.
Ok, so you're saying that 12 minutes isn't enough for it to heat soak, enter data log #2.
This data log begins with the car in my parent's heated garage. Engine temperature is 62.6*F, IAT temp is 65.5*F. No more than backing the car out of the garage, the IAT temp drops to 48.2 degrees. 45 minutes worth of highway cruising later, the engine temp is up to 188.2*F and the IAT is up to 51.8*F.
So what's my point? SAVE YOUR MONEY ON THE IAT RELOCATION KIT. Even if the sensor "heat soaks" at idle, as soon as you open the throttle blades and air actually moves through the intake tract, it's gonna cool the sensor right back down.
Now I'm sure that somebody will want to dispute what I've posted here. If you feel inclined to do so, please have something to back it up with other than "I ran .2 seconds faster at the track." Unless you did 20 back to back passes on the same day and swapped the IAT location on every run, your "data" is likely meaningless.
Old Jan 21, 2009 | 09:41 AM
RacerX70CC's Avatar
RacerX70CC
ET is a function of traction... you would look at the MPH for a percieved HP gain, and this particular mod would likely not show a gain in MPH, thus rendering it useless IMO. I'm with Plemons here
Old Jan 21, 2009 | 09:44 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I will agree, waste of time, especially on my 86 L98, where the IAT's purpose is to help control the EGR .
Old Jan 21, 2009 | 09:45 AM
Nathan Plemons
Because everybody needs EGR.
Old Jan 21, 2009 | 01:13 PM
reoch999's Avatar
reoch999
Just a thought - the tubing is about the right size, if you clean it out real good maybe you could recycle it as a tb coolant bypass?
Old Jan 21, 2009 | 04:44 PM
Aardwolf's Avatar
Aardwolf
I've rather liked having it relocated on the L98, I don't have to mess with it when working on things or swap it between intakes. Thanks for sharing your results.
Old Jan 21, 2009 | 04:59 PM
Nathan Plemons
So long as you're not expecting a performance increase do what you want. I feel the same way about the throttle body bypass. I honestly don't believe it does anything, but I've got mine bypassed anyway just because it makes it easier to work on.
Old Jan 21, 2009 | 07:30 PM
LT4BUD's Avatar
LT4BUD
Are you running the stock air filter system???
Aside from any IAT heat soak issues, it looks like you are doing a great job of getting cool air into your engine!!
Old Jan 22, 2009 | 09:49 AM
BIRDMANmx5's Avatar
BIRDMANmx5
Default intake air sensor
I ran .2 seconds faster with export tail lamps installed
To Thoughts about LT1 IAT relocation (with numbers)
