Does start Don't start
Old Jan 22, 2009 | 06:53 PM
joescvette's Avatar
joescvette
Default Does start Don't start
Have a 1988 anna. that I been trying to find out why, it starts up sometimes & sometimes it won't. You can take a drive with it, shut it off, come back in 10 mins. Sometimes it will start & sometimes it will just spin over. Somestimes it takes 10 mins to start somestimes 20 mins & so on you never know if its going to start. New fuel pump same problem. Its seems that it is not getting any gas. I can spray starting fluid in the throttle body & it runs for a few seconds. Can't drive my car. Can anyone point me in the right direction??? Thanks for any help.
Old Jan 22, 2009 | 09:38 PM
jfb's Avatar
jfb
Get a fuel pressure gauge and connect it to the shrader valve on the end of the right fuel rail when it won't start. You should have 36-42 psi and it should hold up when you turn off the ignition. Rapid pressure drop with ign off tells you that your fuel pressure regulator or its check valve is defective. No fuel pressure, fuel pump or fuel filter. If fuel pressure is ok, then get a noid light from a parts store and check for pulsing on an injector during cranking.
Old Jan 22, 2009 | 09:52 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default Vats
Check VATS. Any codes?
Old Jan 22, 2009 | 10:08 PM
joescvette's Avatar
joescvette
I'm getting 38 psi when engine cranks, stays steady. I will check what you guys said. Thanks
Old Jan 22, 2009 | 10:31 PM
C409's Avatar
C409
Have you tried pedalling the throttle while cranking ? If that helps you probably have a gunked up TB and / or IAC
Old Jan 23, 2009 | 01:11 PM
hgh pwr's Avatar
hgh pwr
my 94 used todo the same thing and it was the ignition switch.
Old Jan 23, 2009 | 03:26 PM
engle1147's Avatar
engle1147
Old Jan 23, 2009 | 04:22 PM
joescvette's Avatar
joescvette
I'm not sure about the ignition switch, because the car always cranks.
Old Jan 23, 2009 | 04:27 PM
Nathan Plemons's Avatar
Nathan Plemons
Sounds like my wife's Alero. It has the new generation of VATS so that the key is normal, all the BS is in the switch. It will always crank but if it doesn't read everything properly it disables the fuel pump. So it might start for a second and then die. Then you can do nothing but sit and wait with the key in the ignition for 10 minutes until the security light stops blinking and goes out.
Old Jan 23, 2009 | 07:19 PM
joescvette's Avatar
joescvette
The fuel pressure stays at 38 psi even when it's just cranking. The fuel is there, but when I check the voltage at the injector it reads 11 volts at both sides. Now its showing a code of 46. My book doesn't show a code of 46, so I checked it twice, & the voltage twice. Still the same. Not sure what's going on.
Old Jan 23, 2009 | 08:00 PM
floridamale's Avatar
floridamale
Check here for code 46
http://www.corvettebuyers.com/c4vettes/ecm.htm
Code46 ; VATS Anti Theft Circuit Fault
With negative battery lead disconnected and using high pressure, non residue contact spray cleaner, spray into area where ignition key inserts followed by inserting and removing key several times. Check for open/short on harness from steering column VATS ignition key to ECM. Possible defective anti-theft module.
Old Jan 23, 2009 | 08:59 PM
joescvette's Avatar
joescvette
Thanks for all the help everyone has given me, I''II get on it first thing in the morning.
To Does start Don't start
