cant figure this one out?
Old Jan 23, 2009 | 02:36 PM
buddylee432's Avatar
buddylee432
Default cant figure this one out?
I have done research on past threads but cant find an answer to my question. Why does my car have a poping sound like a backfire coming from inside the engine compartment. It sounds like it comes from the air cleaner part.??? It also has a backfire from the exhaust sometimes.
Old Jan 23, 2009 | 03:23 PM
engle1147's Avatar
engle1147
My best guesses:
Spark plugs not firing correctly.
Injector flow problems.
Timing may be off.
Valves are not sealing:
Valve/s adjustments are too snug.
Valve/s, spring/s or seat/s are damaged.
Old Jan 23, 2009 | 03:25 PM
toptechx6's Avatar
toptechx6
What have you done to try to diagnose the problem? Start by checking for codes, verify correct fuel pressure, are the ignition wires any good, (open the hood at night to check for arcing), is it due for normal maintenance such as spark plugs, have any repairs been done recently?
Diagnosis starts by testing and eliminating possibilities until you narrow down the root cause, good luck.
Old Jan 24, 2009 | 03:36 PM
josephf31's Avatar
josephf31
Default The first thing
I would check it ignition timing
Old Jan 25, 2009 | 04:49 AM
RRT vette's Avatar
RRT vette
I agree with these guys. My guess is that it is going to be an ignition/timing problem
Old Jan 25, 2009 | 10:21 AM
Iroc57's Avatar
Iroc57
Common sense here...
Set timing
check firing order and for cross firing with the wires
Post results and we go from there
Old Jan 26, 2009 | 02:07 AM
a1231212's Avatar
a1231212
Set timing
Old Jan 26, 2009 | 10:14 AM
383vett's Avatar
383vett
Does this backfire noise come on during acceleration or deceleration? Does the car miss?
To cant figure this one out?
