service ltpws ?
Jan 25, 2009 | 07:48 PM
HELP!! service ltpws ?
I have a 94 coupe.
Every time I take it out I get a warning to service the LTPWS.
It usually takes a while for the warning to appear.
I have never gotten a low tire pressure warning.
Any suggestions or advice would be welcome.
Jan 25, 2009 | 09:28 PM
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Do you have a FSM (Factory Service Manual)?
You can pull the codes for the LTPWS and then advise the codes so we can help.
If you don't have the FSM, let us know and we'll dig out the procedure for you.
BTW, often problems like yours can be tied to a bad ground (e.g. the ground behind the driver side outer kick-panel.
Jan 25, 2009 | 10:39 PM
Have car stored for the winter.
It is 26 below in Winnipeg and we have about 2 feet of snow.
Will pull the codes as soon as I get the car out.
