please estimate chp gain from new heads
Old Jan 26, 2009 | 03:55 PM
matts85vet's Avatar
matts85vet
Default please estimate chp gain from new heads
going from
stock 113 unported heads 58cc 190cfm
to
new afr 180 street eliminator heads angle milled to 58c --260cfm
about 65-70 cfm increase
motor is 350 w/
1204 miniram -- 265cfm
lunati 60103 cam 227/233@.05 110lsa
lift w/1.65 rockers= .538/.554
current combo w/113s dynoed at 273rwhp/308rwtq on mustang dyno
tune was very rich a/f=11
current est hp = 364, est tq = 411
thanks in advance
matt
Old Jan 26, 2009 | 04:17 PM
Andrew's Avatar
Andrew
Matt, I'm not trying to hijack this tread, but running that rich, do your headers glow a little at night? My car seems to be running that rich and have noticed the LT headers glowing.
Now for your question, I don't know the difference, but going from 190 to 260 can only bring good results!
Old Jan 26, 2009 | 11:05 PM
Movnviolation's Avatar
Movnviolation
I would be curious also. I m running about same setup (see profile).
I am having problems getting up and running however. Water running out of headers at startup. Another story!
Old Jan 26, 2009 | 11:16 PM
cv67's Avatar
cv67
St. Jude Donor '05
+60hp minimum, gains will be everywhere too, not just at peak.
Old Jan 27, 2009 | 12:29 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I've seen data where worked #113s gave 30chp gain; those AFRs should net at least this much, assuming the intake & exhaust can handle it.
On the plus side that 11:1 A/F should move toward the desirable 12:1 range.
If you have an A4, assume 17% DT loss; so 273rwhp->330chp. To verify, take it to the strip and use trap speed & launch weight to calc. chp.
Old Jan 27, 2009 | 11:26 PM
JimiHendrix's Avatar
JimiHendrix
My guess is you will gain 1 hp.
Old Jan 28, 2009 | 12:04 AM
Beach Bum's Avatar
Beach Bum
273 rwhp thru an auto, I have that at right around 340 flywheel ponies..... probably good for around 106-108 mph trap speeds or thereabouts.
But, regardless, provided your motor is hitting on all 8, I think you'll make around 400 flywheel HP and even a little above that with your set-up.....should be good for 112-114 mph traps.
good luck !
Old Jan 28, 2009 | 01:24 AM
Yguy's Avatar
Yguy
I'll say two hp. so I'm closer without going over. Let's hope I make it to the showcase
To please estimate chp gain from new heads
