Car started what's up
Old Jan 27, 2009 | 05:54 PM
joescvette's Avatar
joescvette
Default Car started what's up
On this 1988 anna. it doesn't start all all the time. I sprayed starting fluid in the pcv & it started right up, & kept running. Shut it off a few times & it started right up. Can someone tell me what's going on? Thanks for any help.
Old Jan 27, 2009 | 06:47 PM
engle1147's Avatar
engle1147
I wouldn't go spraying that stuff in the PCV valve. Do a "resistance" check with a meter on the "ohms" setting to check the resistance across all the fuel injector coils. They should be around ~16 ohms or so....see if you have one or more low or high.
Old Jan 27, 2009 | 07:25 PM
joescvette's Avatar
joescvette
engle1147, if I have one or more low or high should I change them?
Old Jan 27, 2009 | 07:28 PM
engle1147's Avatar
engle1147
I depends on the variance of what you find.
Old Jan 28, 2009 | 01:39 AM
RogerZ06's Avatar
RogerZ06
Buy some new injectors from FICINJECTORS.
http://forums.corvetteforum.com/c4-t...questions.html
To Car started what's up
