I'm going to perform a major tune up here soon. the vette has sprung a water leak, is still running rich, and has a small oil leak too. So, its going to be torn apart and I want to add some things while in there.
For starters, I've got ac delco rapidfire #5s ready to go in, they will work with gmpp fastburns right?
I also want to replace the wires (two boots are badly corroded). Any suggestion...must be blue!
I also want to upgrade the distributor, coil, and anything else possible. suggestions?
I think I should replace that fram air filter with a k&n while I'm at it too.
I've had the best performance with the AC Delco FR5LS plugs. For plug wires, MSD Heli-Core and Taylor Spiro Pro 8mm wires are direct fit, have low resistance and come in Blue. Also, the stock Distributor, Cap, Rotor and Coil are all that's needed.
