Heads for an 85
Old Jan 27, 2009 | 02:18 PM
Pwnage1337's Avatar
Pwnage1337
Default Heads for an 85
http://store.summitracing.com/egnsea...115+4294925023
Summit is offering "Street & Strip Cylinder Heads"
Do you think they are comparable to AFR or other heads?
Here is the description:
"Don't sacrifice quality for a low price--get both with a set of our Summit Racing Street & Strip® cylinder heads for small Chevy. The lightweight heads are cast from A-356 aluminum alloy and have 200cc intake ports, 64cc combustion chambers, phosphorous bronze valve guides, and ductile iron valve seats for use with unleaded gas. They're also end-milled and drilled for accessories. The fully assembled heads have 2.02 in. intake and 1.60 in. stainless steel exhaust valves, 1.470 in. hydraulic rollers valve springs, 7 degree valve locks, 3/8 in. rocker arm studs, and 5/16 in. guideplates."
I would change the rockers to 1.6 right?
Old Jan 27, 2009 | 02:23 PM
ekess744's Avatar
ekess744
how much money to you have?
Old Jan 27, 2009 | 02:28 PM
ArmyBoyATC's Avatar
ArmyBoyATC
I wouldn't think that these heads are comparable to AFR heads. In my expierince you get what you pay for. If they are such great heads why are they selling them for so cheap? Another thing I wouldn't reccomend getting anything less than a 215 intake ports. If I were going to drop the money on some aluminum heads, I would save my money and get something like AFR or trick flow whatever it is you want, that way you know you are getting quality. I really like the AFR heads. I have heard a lot of good things about them. What mods do you have done to your engine and what do you plan on doing to it in the future?
Old Jan 27, 2009 | 02:33 PM
ArmyBoyATC's Avatar
ArmyBoyATC
Oh one more thing. 1.6 rockers make your cam "think" that it is bigger. If you are pushing the limit on your cam size as it is then dont buy 1.6 rockers. If you have something like a stock or mild cam then 1.6 rockers will help you. While I had the motor apart I would replace the cam with what you want. I would call comp cams and tell them what you want you engine to do and then when they reccomend a cam for your car ask them what heads they would reccomend as far as intake runners and valve sizes. I like to build my motor around the camshaft that way I know that everything will work together well.
Old Jan 27, 2009 | 04:42 PM
Pwnage1337's Avatar
Pwnage1337
Right now the motor is basically stock, except for little mods like cut air lid, K&N filter, cutback plugs, accel super coil. In the next month i plan on putting a 2.25" true dual exhaust system with LT-1 style mufflers on it, then i am going to get a FIRST intake, so i figured while i have the intake off, i might as well go for heads and rockers, possibly cam. Its not going to be a track car, mainly a street car and take it to the track for 1/4 times maybe 3-4 times a summer.
i am also going to put Bosch III 24 lb injectors in it from FIC before all of the stuff listed above. One is bad, so i figure they are all on the brink of going..might as well replace em all.
Also, where do you get AFR heads from? JEGS or summit or something?
Old Jan 27, 2009 | 04:44 PM
steven mack's Avatar
steven mack
Default heads
I called Summit. They said 261 cfm intake 176 exhaust at .600 lift.
Old Jan 27, 2009 | 05:01 PM
Pwnage1337's Avatar
Pwnage1337
thats more than sufficient isn't it?
Old Jan 27, 2009 | 05:33 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
That's pretty good for a cast 200cc head -- especially if you can verify flow numbers. Many head porters will tell you aftermarket heads don't always flow as advertised. For that runner size, they don't flow as well as AFR -- but they aren't CNC ported. It's reasonable to directly compare to TFS, Edelbrock, Dart, Canfield, Vortec, Fastburn or any cast SBC head.
See if you can find feedback on quality/flow.
Compare their pricing to TFS, AFR, and others. Look at flow too -- especially in the ..300"-.400" lift range. They spend way more time at that height than at peak.
The more air your flow, generally the more power you can make. If cost is important, then it can dictate your choices.
Old Jan 27, 2009 | 06:45 PM
Muffin's Avatar
Muffin
Those flow numbers don't mean squat.Noway are you going to get .600 lift . Summitt owns Trick Flow. I wonder if these heads are an El Chepo version of an older Trick Flow head? I don't know. Summitt is not known for selling junque so I would guess the heads are worth the price.
Old Jan 27, 2009 | 07:21 PM
John A. Marker's Avatar
John A. Marker
I really believe that the 200 cc are too big for your 85 without major changes to the cam. Again, let me urge you to read Vader86's web site.
Without going to a bigger cam, and really dumping the intake, runners and plenum you will not see major gains. Go with a set of 180-190 heads or smaller. This would not be a good fit for your car.
Old Jan 27, 2009 | 07:37 PM
JackDidley's Avatar
JackDidley
For a street car you may want 180 or 190s. 200s will be overkill.
Old Jan 27, 2009 | 11:03 PM
383tpimachine's Avatar
383tpimachine
I haveDart iron eagles with 200cc runners on my 383 with stock cam and 1.6 roller rockers
swtiching from the stock heads to the darts even with the 200cc runners gave me a BIG in your face change in power.
Old Jan 27, 2009 | 11:14 PM
powerpigz-51's Avatar
powerpigz-51
I agree that 200cc's is a bit much....as far as being comparable to AFR's etc, thats a moot point.....any aftermarket aluminum head will be a huge improvement over the stock 85 head. I believe the stock ones are in the 165 cc range. My 85 is in the market for an upgrade in that department, and I was also looking at those heads. If your on a budget, the pro Comp 190's are around 650 bucks.
Old Jan 27, 2009 | 11:16 PM
cv67's Avatar
cv67
St. Jude Donor '05
Lot of times mfrs of heads post some .600 lift # so their head looks marketable. For a TPI car who cares what it makes there?
Look for something strong in the low-mid lifts up t0 500+-.
Fwiw 176 @ 600 is SUPER weak, especially for a 200cc head. I got 202 out of a TPI exh port (@600) which isnt really impressive (but not bad) with puny stock exhaust valves/no special cutting done on them so what does that tell you?
If it was at a lower lift it would be more attractive.
Old Jan 27, 2009 | 11:28 PM
vader86's Avatar
vader86
200cc is a bit much considering your plans, and you will need new heads, that much is for sure.
These particular heads are probably worth the price, I just wouldnt buy this set. I would look for something smaller in port size, which may flow better, as most have suggested.
Old Jan 27, 2009 | 11:38 PM
cumbercr's Avatar
cumbercr
I agree! When I contacted AFR regarding heads for my 85, they recommended 180's. With the mods he is talking about, there's more than enough flow. I don't understand why people get concerned with flow at .600 lift? I'd be looking at the numbers between .400 and .500 where the majority of cams perform.
Old Jan 27, 2009 | 11:52 PM
Pwnage1337's Avatar
Pwnage1337
I'm not really educated on the Cam/Heads part of the engine yet. I'm only 17, but I have much to learn. What heads would you recommend for a setup like this (help me with cam?):
FIRST Plenum/Runners/Manifold Combination thing from First Fuel Injection
True Dual Exhaust (2.25") w/ Hedmans Elite Hedders
Open Air Lid w/ K&N filter
Berry scented air freshener (gotta have one)
To Heads for an 85
Old Jan 28, 2009 | 10:44 AM
ekess744's Avatar
ekess744
that would be a good combinations of items to install.
Old Jan 28, 2009 | 10:52 AM
Aardwolf's Avatar
Aardwolf
You might want to use 2.5" with an H or X pipe.
Old Jan 28, 2009 | 02:07 PM
Pwnage1337's Avatar
Pwnage1337
Where would I find a 2.5" exhaust? MAM, CPC, and Ecklers all have only 2.25"
The system i was looking at is 2.25" alumnized steel, manifold back so there isn't any cats or anything.
I saw a chart somewhere that said that 2.25" will be sufficient for engines making less than 350 HP. is that true?
What about these heads?
http://www.fastengineparts.com/produ...ew.php?id=2370
