Have a 1989 corvette basic stock with a cat back and a cold air induction.this car needs injectors.would the accel 24lbs would be better than the 21lbs
I don't think those mods your talking about above will require/need bigger injectors. If you want a little extra fuel get an adjustable fuel pressure regulator (FPR) housing and crank up the pressure to the injectors.
Get with Jon @ FIC Injectors (CF member and vendor) for a correct injector size if you have "heavy" mods coming up in the very near future. Jon does the Bosch III injectors....which have a way better track record than Accel injectors.
