how do you figure compression ratio?
Old Jan 28, 2009 | 01:58 AM
slickfx3's Avatar
slickfx3
Default how do you figure compression ratio?
how to figure?
Old Jan 28, 2009 | 10:59 PM
cv67's Avatar
cv67
St. Jude Donor '05
your heads were not milled. They are box stock.
Old Feb 3, 2009 | 10:16 PM
marksp's Avatar
marksp
I'd be worried if your builder can't figure this out.
The compression ratio is a ratio of original volume of the cylinder to the compressed volume of the cylinder or volume at BDC vs TDC
Assuming a zero deck, .041 Compressed head gasket thickness, 65 cc heads, 3.75" stroke (383), 4.010 Bore (.010 over), & flat top pistons with no valve reliefs.
Head Gasket volume = ((3.14*(4.01^2))/4)*.041 = .515 Cubic Inches
Combustion Chamber Volume = 65 CC's * .061023 = 3.97 Cubic Inches
Cylinder Volume = ((3.14*(4.01^2))/4)*3.75 = 47.34 Cubic Inches
Volume @ BDC = .515+3.97+47.34=51.82 Cubic Inches
Volume @ TDC = .515+3.97 = 4.48 Cubic Inches
Compression Ratio = 51.82:4.48 or 11.56:1
You'll need to determine actual head gasket thickness/bore, cylinder bore, and piston relief volume to get a more accurate #.
Old Feb 3, 2009 | 11:05 PM
slickfx3's Avatar
slickfx3
yes i was concerned and a little worried...
felpro 1003 4.166 .041 thick
mahle -5 cc pitons
4.030 bore which someone said was a 383 bore
Old Feb 4, 2009 | 01:01 AM
rodj's Avatar
rodj
ONLY if it has a 3.750 stroke crank
If stock crank then it would be 355ci
ci is related to bore AND stroke.
Old Feb 4, 2009 | 01:45 PM
silver86's Avatar
silver86
If you're looking for static compression ratio:
http://www.rbracing-rsr.com/compstaticcalc.html
To how do you figure compression ratio?
