Harmonic Balancer Hub!
Old Jan 28, 2009 | 08:37 AM
lilredc4's Avatar
lilredc4
Default Harmonic Balancer Hub!
OK, I have removed the harmonic balancer (1992) and need to remove the crankshaft hub, so I can replace the timing cover gasket and oil seals. The FSM says to raise the motor some to get to the hub, first questions is what is the best way to raise the motor from underneath the car (Without damaging the oil pan) and has anyone used a tool other than the Kent Moore J-39046 to remove the hub, if so can you describe the tool or maybe post a pic, or link with descriptions of how you used it to remove the hub. I understand that the hub is pressed on and you don't want to use the threads as pushing or pulling point to remove or put the hub back on. I think this is right? I did a search but could not find the exact info that I am looking for, any help would be appreciated.
Old Jan 28, 2009 | 12:09 PM
floridamale's Avatar
floridamale
One thing I would do before removal is make sure your timing marks line up with TDC on the mark & piston position. These timing hubs can slip with age better to know before you replace the old hub.
I know because I just replaced my dizzy gear and my hub had slipped a little timing marks were off with piston @ TDC. I have an 87 L98 but I think LT1’s are same setup.
Just a thought easier to check before hand then get it all back together and find out.
Old Jan 28, 2009 | 12:16 PM
RogerZ06's Avatar
RogerZ06
Old Jan 28, 2009 | 12:23 PM
Ryan59's Avatar
Ryan59
Old Jan 28, 2009 | 12:39 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I managed to get mine off w/o jacking it.
I bought a puller a NAPA puller
The threaded rod barely clears the crossmember, but it clears.
Watch the fins on the PS cooler if you have one.
Old Jan 28, 2009 | 12:43 PM
catlettlt1's Avatar
catlettlt1
Try this ,it does work very well i used it when pulling the one on my LT4.
http://www.youtube.com/watch?v=qkh1BNM7e6Q
Old Jan 28, 2009 | 12:44 PM
Ryan59's Avatar
Ryan59
Wouldn't happen to have the puller's part number would you? I'm not sure if NAPA still have a store here or not. Have to order it. Need part number and a picture showing it being used....
Old Jan 28, 2009 | 12:48 PM
joecarter85's Avatar
joecarter85
You will not damage the oil pan if you use a 2" X 8" piece of wood to spread the load. There are only 2 18mm nuts that need to be loosened to raise the engine up. I had to do this to remove the hub from my 'LT4. Do not remove the nuts completely from the mounting bolts.
Old Jan 28, 2009 | 01:24 PM
pianoguy's Avatar
pianoguy
Originally Posted by catlettlt1
Try this it does work very well i used it when pulling the one on my LT4.
That's a keeper
Old Jan 28, 2009 | 01:27 PM
BrianCunningham
Sorry no picks
Just tell them it's for a SBC so the crank bolt it correct.
You'll need it to put the hub back on.
EDIT
This looks like the one I used.
http://www.napaonline.com/MasterPage...alancer+Puller
I put the outer threaded rod through the holes in the hub mount, that were occupied by the balancer.
If the bolts don't fit get smaller ones, and runs the nuts up one at a time till the mount comes off.
Old Jan 28, 2009 | 07:41 PM
lilredc4's Avatar
lilredc4
Thanks guys, the video was real informative and the post about using the piece of wood to support the oil pan. Will not get to work on it until the weekend, but now I know what tools I need and how to use them, thanks to this forum and it's participants.
Old Jan 28, 2009 | 07:59 PM
BrianCunningham
That's how I did mine
Old Jan 29, 2009 | 05:32 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
I have been renting out the Kent Moore tool PM for details.
Old Feb 21, 2009 | 10:16 PM
rickneworleansla's Avatar
rickneworleansla
Well, how did it go? I'm at this exact pont right now. I need to get the hub off in the morning. Is the hub and timing gear keyed to only go on one way?
Old Feb 21, 2009 | 10:29 PM
STL94LT1's Avatar
STL94LT1
Nope.
Old Feb 22, 2009 | 10:05 AM
MikeC4's Avatar
MikeC4
although not keyed, the Hub was installed with the arrow to point at 12:00 at #1 TDC(assuming cam gear "dot" is at 12:00) . So the "dot" on the crankshaft gear, the arrow on the Hub, and the arrow on the pully balancer will all be at 12:00 position.
Old Feb 22, 2009 | 03:41 PM
MK 82's Avatar
MK 82
LT1 doesn't have a timing mark. Not needed as timing is not adjustable.
To Harmonic Balancer Hub!
