roller rockers
Old Jan 29, 2009 | 12:33 AM
pologreen1's Avatar
pologreen1
Default roller rockers
1.6 rr's self aligning
will these work on my car ok?
http://www.jegs.com/i/Comp+Cams/249/1418-16/10002/-1
headers extension pipe
also I have mamo straights, so can I use these to connect the pipes at the joint to the header, instead of cutting the front of the straights that bend up to the stock manifolds?
http://www.jegs.com/i/Flowtech/387/10010/10002/-1
thanks guys
Old Jan 29, 2009 | 12:53 AM
bigwave71's Avatar
bigwave71
Originally Posted by pologreen1
1.6 rr's
http://www.jegs.com/i/Proform/778/66908/10002/-1
thanks guys
im thinking you need the self aligning roller rockers.
Old Jan 29, 2009 | 01:02 AM
pologreen1's Avatar
pologreen1
ok that is what I thought thanks
Old Jan 29, 2009 | 11:49 AM
rickneworleansla's Avatar
rickneworleansla
I believe I was told to get the NSA rockers for my cam swap. I've been looking at these.
Comp Pro Mag 1.6 7/16 1305-16
Old Jan 29, 2009 | 12:05 PM
Ryan59's Avatar
Ryan59
I went with the Crower Enduro 1.6 7/16 stainless steel. This rocker arm has needle bearing pivot and will clear large diameter retainers. They have been around for decades. I've never heard of one failing.
Old Jan 29, 2009 | 01:43 PM
pologreen1's Avatar
pologreen1
thanks guys
To roller rockers
