Turn Signals/4 Way
Old Jan 29, 2009 | 08:43 AM
FNSIII's Avatar
FNSIII
Cruising
Default Turn Signals/4 Way
Where is the flasher module on the '92 model?
Old Jan 29, 2009 | 09:05 AM
pianoguy's Avatar
pianoguy
I believe it plugs into a harness on the back of the instrument panel to the left of the steering column - you'll have to remove the hush panel to get at it.
Old Jan 29, 2009 | 06:18 PM
c4cruiser's Avatar
c4cruiser
There are separate flashers for the turn signals and the 4-way hazard flashers.
The turn signal flasher in on the lower left corner of the instrument panel. Remove the hush panel and it will be above a set of 3 relays. The case will most likely be yellow or green plastic.
The hazard flasher is clipped to a mounting bracket directly behind the radio receiver box. That box in at the bottom of the RH side of the dash near the RH kick panel. The hazard flasher will probably look the same or very close to the turn signal flasher.
To Turn Signals/4 Way
