Are these the correct gaskets??
Old Feb 1, 2009 | 02:41 AM
Qiken's Avatar
Qiken
Default Are these the correct gaskets??
I have purchased a Small Block Chevy Intake Manifold set for TPI online and after reading the information contained in google search 'choosing TPI unit' It states that the intake manifold gaskets for the corvette are different than for other tpi's'?"
Can anyone confirm that this set is ok for my 89?
Purchased from Ebay seller bigsail720 (read feedback to view items as he has none listed at present)
Old Feb 1, 2009 | 10:00 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Looks good to me.
Yours
Summit's
Old Feb 1, 2009 | 01:37 PM
GKK's Avatar
GKK
I bought this TPI Gasket set from Summit which had the Rear intake coolant passages blocked off like the Stock TPI gaskets.
Part #QMS93318 For Corvette 5.7 TPI
Old Feb 1, 2009 | 04:03 PM
SunCr's Avatar
SunCr
The Vette L98 uses restrictors on the rear of the manifold gaskets to provide additional cooling at the rear of the heads. The F-Body's do not. No problems have been posted when using the F-Body gaskets. The '91 L98 and current production 113 heads have counterbored bolt holes for gasket retainers to maintain intake gasket alignment. GM made this change to stop recurrent intake gasket leaks which led to glavanic corrosion and head gasket failure. Intake gaskets are offered for these heads with and without the restrictors, though finding the '91 Vette (with the restrictors) is getting more difficult since that production was a relatively small number. The rubber pieces for the rear and front of the manifold are strictly aftermarket pieces and there have been quite a few posts showing that they don't work - recommend you use silcone as outlined in the Shop Manual instead. Also, pitted surfaces on the coolant passageways may require a thin coating of silicon to keep them from leaking and if you've got signs of galvanic corrosion, you might want to check out the entire cooling system, cylinder #7 for head gasket leakage.
Old Feb 1, 2009 | 10:24 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
You will find some Vette owners PREFER to install the non-Corvette gaskets. This thread provides add'l background. (Though it's not really needed after SunCr's thorough explanation.)
Old Feb 2, 2009 | 01:21 AM
Qiken's Avatar
Qiken
The intake gaskets for information are corteco #823415,hope these are a resonable brand name??
Thanks All,and to SunCr for pointing out the useless rubber pieces,as I would have fitted these without thinking.
Old Feb 2, 2009 | 10:53 AM
GKK's Avatar
GKK
Also, use the "Right Stuff" (from Permatex) to seal the ends of the intake. It seals a lot better than RTV and will never leak again.
Old Feb 17, 2009 | 06:43 AM
jeffp1167's Avatar
jeffp1167
I think it was because the f-body tpi after 1986 used that different angle center bolts on its lower tpi intake while the vette continued using the standard bolt configuration. I think also the rear coolant ports at least on one side of a f-bodies lower intake has to be left open for coolant flow to the heater core.
To Are these the correct gaskets??
