Sparco Torino Seats
I know of several other seats that also fit (most are a fixed back), but I'm just interested in an answer to this particular seat.
Thanks!
I'd like to know if someone has them in, & if any modification had to be made to the ****.
Thanks.
Shoulders Width: 22.1"
Cushion Width: 19.2"
Cushion Length: 24"
Maximum Height: 35.4"
Corbeau A4
Shoulders Width: 21.5"
Cushion Width: 18.5"
Cushion Length: 21.5"
Maximum height: 35"
The dimensions are within reason, but it is hard to tell from the pics if the rear adjuster is about the same as the front cushion width, or if it really sticks out. I have no problem removing a **** & replacing it with a flat bolt head for a wrench. With these dimensions, it should fit, but I have no rear width (with adjuster included) dimensions for either seat. Do you have a measurement for your Corbeau A4s?
I'd just like to get some rear dimensions for the Sparco Torino from a retailer, or see see one installed in a C4 before I buy it.
Here is a pic of the Sparco Torino:
Here is a pic of the Corbeau A4:
Specs:
One of the most advanced adjustable sport seats ever manufactured by Sparco. Anatomic, extremely comfortable and in a refined and modern design. Back rest can be reclined to the millimeter, but features the exclusive QTS Technology (quick tilt system) technology for rapid return to the upright position. The Sparco Torino II also features a revolutionary contoured injection molded memory foam. Touring car inspired g-force absorbing side bolsters. Perforated abrasion resistant inserts, and a micro-fine recline mechanism. Fabric: Jacquard
Sparco Torino II Features:
# Micro Adjust : The micro-fine recline mechanism can be adjusted to the millimeter to guarantee the perfect seating positing. Extensive research and development has been performed by Sparco Master Certified Safety Engineers to insure that the strength and integrity of the Micro Adjust Mechanism exceeds our strict homologation standards.
# Memory Foam : As body heat transfers into the high-density injection molded memory foam, the seat contours to your body. The perforated leather on the center portion of the seats helps to assist this transfer. The perforated leather also helps to promote air circulation throughout the seat to aid the cooling of the leather on warmer days.
# Lateral Support : High performance lateral side bolsters keep the drive in the optimum seat position at all times. This is especially vital when cornering at high speeds. The side bolsters keep your body in an upright driving position helping to fight driver fatigue during high performance driving.
# Quick Tilt System : The revolutionary and exclusive QTS (Quick Tilt System) technology allows the backrest to be returned to the upright position or tilted forward for access to the rear seats in a two door vehicle
# Abrasion Resistance : Perforated abrasion resistant inserts are strategically placed to protect the seat against excessive wearing in at risk sections.
The Corbeau A4 is very similar, but I am interested in the Comfort, & slight differences that Sparco offers.
Anyway, I thought the dealer said the A4 now comes in the "jacquard" type fabric.
Does anyone know if you can bend the shoulder wings back? I think it's a steel frame seat. If not for this issue I would have a pair of A4s on order.
I can get a new set of Sparco seats at nearly 1/2 price, so I'll probably just buy them, & take a chance with the fitment. I'd just like to see them in a C4 first (if possible).
That picture of the red seat makes me think that the **** will very much be in the way of the stock seat belt housing. So I don't think they will drop in and fit. You can probably shift the seat toward the tunnel for more room. Plus make a smaller adjustment ****. Ask a place that sells them to measure the back from the **** to the other side of the seat to find out. Let us know how they work.
